Let engine run for about half hour total, that way all coolant and water is mixed.
Drain out when cool (collect all this in clean pan for reuse)
Close drain and add 1.3 litres neat coolant (concentrate) - if you accidently removed more than 1.3 litres just reuse the drained coolant to top up. (Dont add plain water otherwise you will upset the mixture ratio)
After running half hour your coolant will be completely mixed at perfect 50% ratio.
Next time when you fill any car with coolant after flushing, dont premix coolant, add concentrate to car and then top off with water as there will always be trapped water in engine or heater. You will get your target 50% very easily. (This is also why I despise ready mix 50% coolant sold at shops, I only buy concentrate, the ready mix they sell is only for topping up or to use in coolant exchanging machine, never for initial fill after flush.
Btw, did you see junk or rusty water drain out when you acid flushed system?
