Issue is mostly with clutch throw out bearing which requires replacement, if one is going for this job then it would be better if you replace clutch plate and pressure plate along with it.
If you are looking for a temporary solution, then bleed your clutch oil, keep bleeding it till the time old one is not replaced with the new one. that would loose your clutch and would make it soft and that may solve your problem without going into bearing replacement.
