So my Honda City 2016 battery keeps dying and requires to be replaced after a years use. This is the third time I've replaced the battery and it's happening again. I replaced the batter on october 2024 and it's showing the same symptoms again before it expires. So first the digi panel dies off and the AC which is also connected to the panel stops working. Then the car battery keeps dying off and requires a push start or jump start. I really need advice as to what could be the issue. At first i though it to be a fuse issue but when i took the car to get the fuse checked. It all came out fine. Idk what's the issue.
