One of my rear wheel is slightly bent (toed in). My car does not give a smooth ride even after best of alignment. Someone has suggested me to get the tube corrected. Need suggestion on this
did you get the rims checked in some cases they get bent if you hit a pothole at speed
You can opt for a repair if bent
During wheel balancing they say rims are ok. Is there any other way of checking the rims
Well...if rear wheel is bent then you will have to change it to get smooth ride...
They will bubble when you spin themIn my Mark 2 grande all 4 rims were slightly bent and the car used to vibrate above 100 got them straightened and no more vibrations
Just discovered that i need to install cam bolts. Lets see if it fix problem
