Hello friends, I’ve used my brake pads and brake oil for 55k and they are still in good condition. Almost 70% used brake pads. But brake oil level has reduced from middle mark to minimum mark. What can be the reason for this and is it bad? Can I keep driving like this or do I need to get brake oil changed. Car is Honda City 1.3 Manual 2015 model.
don't worry level is low due to pads wear
Change both.
But pads seem good. Got them checked a month back
As per your car service manual do what is written in it.
You said 70% already used, whats bad in replacing them to prevent an accident.
Never risk to change anything if your life depends on it.
Lower brake oil level indicates the brake pads are worn out. Whenever you will change the pads oil level will rise to max mark. No need to top up unless the level goes below min mark.
