How much is the fuel reserve in the City current model? In my city, from full to E line, it fills up to 32 liters. So it means there is 10 liters reserve?
low fuel light turns ON at 7.9L while after E line ends there will be 5L petrol. . .at F line there will be 40L and 42L is above Full line !KK
righto
thanks
I also had the same problem. Car was showing range 10 KM. I refilled the tank but it gets filled after 34 liters. I asked the gas station attendant to fill it but he said that fuel is already over. I was expecting 41 liters as tank capacity is 42L but it took only 34 liters. Why is it so?
last red line means 6L. . .range goes to zero prior to 6L mark. . .when range says zero kms u actually have 5-6 L in tank. . .low fuel light blinks at 7.9L. . .the lowest guage level sensors are not v accurate so usually it indicates low fuel light at 10L roughly and touch last red mark at 7-8L. . .34L refill is accurate as ur reserve 6-7 liters were already in tank !KK
Thank you sooo muchhh
