My Honda city 1.3, 2015 is suddenly reducing a lot engine oil. Just recently I checked it after only 2500km and it has reduced about 1liter oil. It is driven 116000km total. What could be the issue please guide me. Thank you
fake oilunless ofcourse its dripping
check pcv valve, amongst other things.
I have tried different sellers in Islamabad but the issue is same
did u recently buy this carthe cars model and mileage doesnt make sense with this issueif pcv valve doesnt fix it, it might b worn out oil rings
compression test wet & dry values will help. any value under gradually going down below 150psi meansa.. valve leaking - head job required b.. rings weak - overhaul required
@rajaatta can you check his car
Seems like normal engine detoriation. Rebuilding it would be easier plus replacements are also available with compatibility of low viscosity oils
I am using it for 4 years now
