From wikipedia
[INDENT]VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles. This was the first system of its kind. Different types of variable valve timing and lift control systems have also been produced by other manufacturers (MIVEC from Mitsubishi, AVCS from Subaru, VVTL-i from Toyota, VarioCam Plus from Porsche, VVC from Rover_Group, VVL from Nissan, etc.).
(intelligent-VTEC) introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the U.S.). In the United States, Honda first debuted the technology on the 2003 Honda Civic Si EP3 with the economy version.
Valve lift and duration are still limited to distinct low- and high-RPM profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuration) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to somewhat advanced at full throttle and low RPM. The effect is further optimization of torque output, especially at low and midrange RPM.
[/INDENT]In City 09 onwards; you will feel the difference how it responds after 2500 RPM (if I am remembering right; I am no longer City owner)
