Kindly share the picture of that mark
Ok I will
stay away higher mileage
@fastian04. How to remove this?
Try some APC maybe!!
https://a.aliexpress.com/_dURtTf6https://a.aliexpress.com/_dT2y6YY
totally worth it it changed interior look significantly. plus it has good quality than oem.. and easy to install
Apc is one option but i see its a synthetic leather.. doesn't seem aspire. U can use following two method's.
Petrol+ surf mixture
Pencil eraser
If u have apc like cg citrus clean, 1:8 would do the job. Use tooth brush..soft one to agitate
Can u plz share the link for this
Aoa bro,I saw you repairing your honda city's Shark antenna. I ve lost mine i dont know how it fell off. Now i want to get a new one, can you tell me whats its price?
20k OEM
Rs. 700 - aftermarket
20k for shark fin antenna?
I'm not sure now, but one of my friends asked Honda and they quoted this price 6 months back.
It can't be 20k ... aftermarket options are available
It is usual from HONDA 3S shops. They quote 8k for a duplicate key. I got it done from roadside in 800. Quality is also good and working fine. Actually my original key with remote was getting stuck sometimes and key guy told me that it can damage the ignition if not changed. I had the one without remote key totally unused. They copy it on machine for new one and installed the original remote in it.
800 for a key, does you car have a immobilizer?
Its true. A worn out key damages the ignition. Good decision 🏼
No I have 2013 CITY. Its cost of a duplicate key only. I check many shops and only two persons were making Honda keys. Both were asking the same amount. I was using my other original key and I did not want to use it a lot because to make a duplicate key you need one original unused key.
I just called Honda Horizon and asked about Shark Fin antenna. They said its not available at the moment, but the last time, when it was available, its price was just Rs 35,000 ONLY.
