I have problem with Honda City 2013, Error is "Torque Sensor Coil Malfunction" i observed that when there is a shock or bump on the road jolted the car, the EPS error light on, while investigation with scanner code emerge " Torque Sensor Coil Malfunction". after removing the error with scanner i have same problem when there is a bump on the road which results in shock or herm to the car. My mechanic said there is problem with the sensor sensing. it is particularly when the car hits bumps or road shocks.
- is it caused by wiring or connector?
- is it due to torque sensor faulty?
- is it due to EPS ground point connection?
Would anybody suggest the solution.
