Its at the back of engine where exhaust is joining the engine, ill try to send a pic also
Ok will wait for ur pictures
After sensor replacement i had to travel on motorway and results are in pics.
Was maintaining rpm of 2.7 approx.
Just curious is this sensor present in 2004 manual Idsi?
Has any one else replaced this air-fuel ratio sensor and what was the result??I am facing the same issue of bad fuel average. Just found this thread and now planning to change this sensor. Lets give it a try.
Hi Faiq, please go ahead changing these will have positive impact. Before that do check graph readings of both sensors. Kabli sensors is a gamble, ensure the part number is exactly same, you can order brand new as well just stick to the actual part number.
Is it SMOKE SENSOR?
Its called oxygen sensor or air fuel ratio sensor
I changed it with the same part number. Before changing my city was giving 9km/l withoit AC. Now 10km/l with AC on not enterily but you can say 50% of the time. Not that much difference though. Any suggestion?
What is LTFT and Injector pulse?
You changed with brand new or kabli?
I changed it with kabli and i dont know about LTFT and injector pulse please guide me
Facing the same issue with my Vario 06' . Also could anyone tell how the fuel gauge of city works, my gauge is malfunctioning!
Kabli is a gamble, you need a brand new one i did the same mistake, the ready from the sensor makes a huge difference actually.
In scanner you will get a reading of Long Term Fuel Trim LTFT
Its connected to the fuel pump right under the handbrake.
Bro i have city 2007 and i am getting 400km in a tank, in 35 liters, is it good fuel average or not.
Well its alright, not sure about driving style and maintenance history
I drive under 3rpm , actually recently i purchased this car totally driven on petrol family maintained car, and recently i upgrade tires r13 to 185/65/r15 yokohama. Now after upgrading tires i feel some bumpy on suspension and getting low fuel average ...What you suggest should i go for 175/60/r14.Can you please tell me what's the perfect allow wheel and tire size for honda city...
