Hi Everyone,
I had a weak engine, reducing oil so went to an Swap, previously had L13 this time opted for L15A2 idsi after reading the reviews.
Till now i have driven about 3000 km, the drive is smooth like anything but the only issue is BAD FUEL AVERAGE, hardly getting 10 km/ liter even on motorway with rpm not exceeding 3k.
Electrician checked the wiring which had a problem and was fixed and tapped all over.
I am using iridium spark plugs, TB serviced, oxygen sensor changed but no success. The last to check is MAP sensor, ive tested with OBD scanners all readings look fine, but mile is just not acceptable.
If nothing works for me i will try to change the engine back to L13 but that would be my very last option.
Any help would be appreciated.
