Hello Everyone,I am planning to change all 4 shocks for my Honda City aspire 2012 model also planning to change the engine foundations. The reason of doing is to make car more comfortable. I need recommendations from where to get them replaced also if someone recently had change shocks or foundation and update me on the estimate. Should I go for kabli parts or new and should get it replaced from dealership or any other good workshop?
You should always go for new parts, and you can get it done from dealership but they always charge more than normal workshops.
You are in Isl/Rawalpindi, right?
You can get it done by @dani_kk Or @rajaatta
I want to get rough estimate before visiting any workshop that how much it gonna cost me for 4 shocks replacement and all engine mounts
Keep around 70k-100k with new parts in mind may be more.
Thank you for letting me know. Do you own a city if yes just wanted to know if there is slight vibration in steering when engine in idle. I mean only little vibration can be felt when you put your hand on steering. You can feel that engine is on. Is this normal or not?
Yes i own honda city.There is a little bit of vibration in the car in steering wheel on idle.Othwewise it is very smooth.But get you engine mounts checked.Mostly due to Timing mount this issue is exagerated or bad coils or spark plugs could be a reason
i have recently installed the new spark plugs as i bought this car recently. The RPM is also perfectly set 750-800 at idle. The vibration is very little and can be hardly felt and as you said there is slight vibration in your car too so i am assuming its normal. I mean if you compared it with civic or corolla you can feel vibration but i think its normal in city.
Get engine mounts and Spark plugs and coils checked.For being on the safe side.
Any recommendations for a good workshop in twin cities?
Visit D motor Sport in Islamabad. By @dani_kk or @rajaatta. Mentioned by the member above.Both are good.
