Hi,
I have read on internet that there is a fluid filter for CVT Transmission Fluid in Honda City Vario.
I am planning to replace the CVT Fluid. Is it easier to replace the fluid filter as well?Has any body did it?
Thanks,
Salman
AoA,I also own this same car and i have the same query.Does it have a cvt fluid filter
Is it failing?
Today D light was blinking after driving for 50-60kms then I restarted the engine and it was back to normal.I changed the transmission oil last week and the mechanic poured all 4 liters..Oil on Dipstick is also a little high could that be an issue i.e overfilling transmission fluid
Get the system scanned for the error before anything else, it maybe a starting clutch worn out issue, your mechanic will need to tear down the transmission to repair it.
Okay sir Thank you for your responses
@Xulfiqar I sent you a DM, kindly reply when you have time
Back in 2009 I encountered same issue with my car. Honda dealership at that time had no clue n suggested to replace whole transmission so ended up selling the car.
