bumping an old thread..
i have same iacv.
the car is my old civic, discussed in other threads as well. the engine is in factory condition. nothing replaced or aftermarket.
issue happened suddenly and for no apparent reason. car is stuck in high idle. approx 1300-1400 rpm.
before it went to fast idle when car was cold, and returned to normal 800 rpm when it got to operating temperature.
now it just goes to fast idle and stays there.
the car temperature sensor works fine. needle is working fine, fan is turning on automatically.
i have hondash scanner, its showing the temperature correctly as well. so i think its not a sensor issue.
i have cleaned the throttle body 2-3 times. cleaned the iacv as well. everything is squeaky clean. the iacv is rotating freely, no carbon buildup at all. cleaned it really good.
strangely the hondash shows 0% duty cycle iacv on idle condition. but shows some different figures when the engine is revved or normally driven.
what values i should be looking for?
how should i go about diagnosing it and not just throwing parts at it.
@Hassan1991
@Xulfiqar
