I am using honda civic 2008 recently car is giving jerk while shifting from P to D or R not regularly and sometimes while driving also. I recently changed all oils and mechanic changes wall body or solenoid but issues is not resolved.. kindly give suggestion on this or recommend good mechanic in lahore
Get it's mounts checked
Can you suggest good mechanic
The problem is in the pressure control valve body, which I doubt the mechanic has even touched.
Its literally the first part after the bellhousing inside the transmission. Meaning to work on it, you have to tear it apart to bits.
@syncview
this is common problem in these models, requires complete gear disassembly and an expense of about 60-70 k including parts and fluids and labour
