[quote="lazers, post:2, topic:452200, full:true"]
This key is with immobilizer right ? I guess you will have to get a new key and get it programmed on ECU. Once the new key is programmed, the old one will be useless as far as starting the engine is concerned. Does your key also has lock unlock buttons ?
I only know of Honda who program the new key onto the ECU. Maybe others know a place other than Honda.
[/quote]
Go to Honda 3S They will give you a new key. or you can buy from outside as well.
The car's immobilizer system can store up to three (3) keys at a time.
All you need to do it to add new and delete old key. and the key can no longer be used for ignition or key less entry of the car.
How ever for the driver Door and Trunk, you need to replace the locks and make new Key accordingly.
Keep in mind doing all these things would cost you more than 7k or 8k
but it is a must do thing to do and I would highly recommend you to do it as soon as possible.
If you think my reply is a solution, please click on the solution button below.
