Your car requires Honda DW-1 ATF. Get it from Nasir Motors Plaza, Karachi. How much is your car driven? If the transmission fluid has been replaced every 40K KMS, you can go for a simple fluid replacement as per the Honda service manual.
1.Bring the transmission up to normal operating temperature (the radiator fan comes on).
2.Park the vehicle on the level ground, and turn the engine off.
3.Remove the drain plug (A), and drain the automatic transmission fluid (ATF).See the upper arrow in the diagram.
4.Reinstall the drain plug with a new sealing washer (lower arrow in the diagram).
5.Refill the transmission with the recommended fluid into the dipstick hole to bring it to the upper mark on the dipstick. Always use genuine Honda ATF-Z1 or DW-1 automatic transmission fluid (ATF). Using a non-Honda ATF can affect shift quality.
Automatic Transmission Fluid Capacity:
2.4 L (2.5 US qt, 2.1 Imp qt) at change
5.9 L (6.2 US qt, 5.2 Imp qt) at overhaul
6.Insert the dipstick back into the transmission.
