Greetings pakwheelers Recently i Travelled from lahore to sargodha on my Rs it went perfectly fine the pick the turbo kick everything was fine but on my way back rain started and when i pushed it and when the turbo flutters it gives sound from under the steering wheels and doesn't flutter like before the car doesnt have the same pick i am going back to lahore without pushing it It is running perfectly fine even on 130/40 but as i push it the turbo give strange sound from unusual place that is under the steering wheel back into the engine compartment
You are now in Lahore, right?
If so then visit @syncview he will diagnose and treat the problem.
Call before visit.
Did you put fuel from Sargodha
agreed with above diagnosis, bad fuel, cleaning or changing spark plugs and getting good fuel might solve this issue, must give it try before going in deep
No i didnt put fuel in it from sargodha got it full from lahore with high octane
I recently got it tuned from honda as well maybe 2 months back
including plug change?
Yes
I would say to consume full tank Refill with mix ratio fuel
Then drive to see. If initial oick is ok but at higher end you are facing issue, it could be
Theres no problem at the higher end Its just when I initially pushes it and when the turbo kicks or when ever the turbo kicks it makes weird noise
Drive for few days and observe
Ive Got it Check from Honda And they Said iske silencer ke jali phat gaye ha and have given me an estimate of 61 thousand is this legit or should i get it check from somewhere else
Check from outside
