From where is it leaking? Going for EPS instead of fixing simple leak with few thousand is not worth it.
If pump is leaking, you can get the oem seals changed, all in 2k.
If pipe is leaking, you can go for a kabli pipe in around 2-3k
If intake pipe is leaking, then that is for 900-1200 rs from dealership.
Use only Honda PSF.
