Aoa es squad,
I am back with another problem. Back in the days my car was consuming oil, we are talking about exi 05 here. I thought it was because of weak piston rings most mechanics also guessed the same and suggested to let it run until it dies. Last night i was reading reasons why my car is consuming oil, i came to know about valve seals, the main symptom was that if you cold start car you can see bluish white smoke for few seconds, Yes i see that in my car even smell oil burning. So now i think my cars valve seals are bad which should be fixed, i also read about weak pistons rings that take dipstick out of engine while car is running if yiu see steam coming out it is weak piston rings. Now guys suggest me what should I do , should i go and get compression test done first and if it is positive I should go for valve seals? Right. If not what should be done.
Lastly please mention all costs including parts and labour also a trusted shop/mechanic in isb for compression test and mechanical work, i recetly shifted from pindi so dont know any mechanics here.
