Hi Pakwheelers,
I have Honda Civic 8th Generation which I am using for the past 2 years. Its a full option Automatic varient. The issue that I am facing is in its tranmission I recently changed its tranmission fluid with original Honda ATF. Every morning when I start the car the gear is unable to switch from 1st to 2nd and if it does then a sudden jerk occur and the RPM goes from 2000RPM to 3000 or even 4000 RPM.
I went to mechanic and after the diagnostic report it shows an error p0796 i:e pressure control solenoid C is stuck and the mechanic suggests to change the whole transmission.
Please let me know any other possible solution, DIY or any good transmission repair mechanic in Lahore.
That will be a big help.
Thanks and hoping to hear from you soon.
