Hi Experts,
I am facing an issue with my 9th gen civic that the door ajar indicator is not working when the car is switched off and i open any of the doors or the trunk. As soon as i turn to ignition to Accessory mode or start the car the door open indicator in MID as well as in the dashboard start working normally.
This issue was not present before, but recently i drove my civic on a extremely patchy and bumpy road after which it started malfunctioning. I suspect that there is some loose connection but kindly guide from where should i start troubleshooting it.
On a side note, i have checked all the fuses in the internal and external fuse box and all the intact. Also, even the dome light is working normally on opening and closing of the doors. It is just the dashboard door ajar indicator which is not working while the vehicle is switched off.
