Did u press the menu button to see what the message is when that icon appears at bottom right?
No message, checked multiple times nd it disappeared it self
Same here no message nd disappeared it self.When ac is on engine is giving heavy sound do you know any issue like that in 9th gen? When ac or fan is off no sound
Check cat con
Even though it’s not my car it’s Abba gee’s and he doesn’t let me drive his car often because of my driving skill (According to him) but yeah AC puts a bit of load on engine. Not that much but still.
Can definitely answer queries related to 8th gen because i still have her ️ My baby
Yes cat con is missing , but there is no error on obd for cat con and fuel avg is quite good on long route in 14-16km/l
Can you please tell me that where its radiator heat & cool gauge is displayed?
There is none9th gen has a blue and red light turn on in the gauge cluster in case the engine is cold or overheating Also incase of over heating a message comes up on the imid
Check the female portion of your seat belt (where you lock your belt) there is a sensor there, i assume due to dirt/ misalignment its not clicking as it should be, by time it engages and alarm disappear. i wish it helps you.
No my temperature sensor is broken due to a small accident.
Can anyone support here please?
what kind of ?
I am facing an issue in civic 2014 prosmatec auto transmission. When the car is accelerated from (speed 5-15 kph) there is a grinding sound on releasing the accelerator if speed is in range of 5-15 kph. This sound goes away when the gear is shifted to second and third. Can anyone help or explain the issue if experienced this issue.
Salam everyone. I'm thinking of buying a 2013 or 2014 civic. I had a couple of questions if you experienced people can help:
change the fluid transmission hope it can work
Already done but no effect. Seems like some bearing type sound only whn accelerator is left alone. No sound while accelerating
to identify if its from transmission or something else, safely put the lever in N during cruising and observe, if it disappear it surely from trany, if it remains it may be something else.
Any good mechanic who is good for maintenance of civic auto transmission in pindi/islamabad??
Salam. Hello 9th gen owners.A little review from me of the 9th gen civic. Hope you guys like it, if you do subscribe and support the hard work please jazakAllah.
go for honda dealer ship
