Hi PWs,
I have Honda Civic 2007 model can be viewed through this link: has developed a weird issue. Asal main hota kya hai k its AC works very fine when cold engine starts till the time its radiator sensor sends signal ECU to trigger start its radiator fan. The moments its the right time for the radiator fan to start, its AC compressor immediately stops working until engine cools down to 25% (normally coolant temperature reaches on 50% to trigger radiator fan). As far as I know and my THORA BOHOT TAJURBA either the Compressor thermal cutout/sensor/switch is bad OR it has some kind of electrical link with the coolant thermostat because as soon as the radiator fan starts due to getting signals from Coolant thermostat the next time the AC compressor immediately stops working. Samajh nahi arahi kya karna chahiye, I live in Islamabad or main ne har SARAK CHAAP AC tech ko check karaya but to no avail. I had its complete service, full Gas recharge etc lekin masla wahin hai. Any one who has faced same issue or is there any solution through ECU tempering (koi aisi coding kar de takay Thermal sensor by pass ho jaye etc).
