[CENTER] [ATTACH=CONFIG]288926[/ATTACH] [ATTACH=CONFIG]288927[/ATTACH]
Features
[/CENTER]
Engine
- 49cc four-stroke engine produces 7 bhp at 13,500 rpm.
- HRC(r) racing parts include: camshaft, valve springs, low-friction cam chain, crankshaft and lightweight AC generator.
- Six-speed close-ratio transmission.
- Big-bore carburetor and special manifold for optimum power.
- Race-ready engine features oil drain bolt with hole for lockwire to comply with race regulations.
<font color='#000000'>Chassis/Suspension</font><font color='#000000'> </font>
- Lightweight and strong steel frame.
- Weight-saving aluminum fenders front and rear.
- Aluminum oil catch tank.
- Showa(r) front and rear suspension are calibrated for the track to provide optimum handling and stability.
- Exhaust system features a one-piece expansion chamber and muffler.
<font color='#000000'>Additional Features</font><font color='#000000'> </font>
- Tachometer capable of showing 18,000 rpm is directly mounted to frame.
- Front number plate and chainguard as standard equipment.
Model: AR02
Displacement: 49cc
Bore x Stroke: 40.0 x 39.6
Compression Ratio: 11.7:1
Max Power: 7 bhp
Carburetor: 20mm
Ignition: CD
Clutch: Wet multi-plate
Transmission: Six-speed
Overall Length: 70.5 inches
Overall Width: 24.2 inches
Overall Height: 37.2 inches
Wheelbase: 47.0 inches
Dry Weight: 156.5 pounds
Fuel Capacity: 1.6 gallons
Brakes: Single hydraulic disc front and rear
Tires
Front: 2.50 x 18
Rear: 2.50 x 18
Comparison to Standard Dream 50
<table style="border-collapse: collapse; width: 328pt;" border="0" cellpadding="0" cellspacing="0" width="437"> <colgroup> <col style="width: 94pt;" width="125"> <col style="width: 117pt;" width="156" span="2"> </colgroup> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border: 0.5pt solid windowtext; padding: 0px; background: none repeat scroll 0% 0% yellow;" width="125" height="17">Model No</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: 0.5pt 0.5pt 0.5pt medium; border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% yellow;" width="156">Dream 50 Standard</td> <td style="width: 117pt; color: red; font-weight: 700; text-align: center; vertical-align: top; white-space: normal; font-size: 10pt; font-style: normal; text-decoration: none; font-family: Arial; border-width: 0.5pt 0.5pt 0.5pt medium; border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% yellow;" width="156">Dream 50R</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Model</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">A-AC15</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">AR02</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Overall length (mm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">1,830</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">1,790</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Overall width (mm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">615</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">615</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Overall height (mm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">945</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">945</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Wheel base (mm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">1,195</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">1,195</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Dry weight (Kg)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">81</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">71</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Engine model</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">AC15E</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">AR02E</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Displacement (cc)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">49</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">49</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">BoreXStroke (mm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">40.0 X 39.6</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">40.0X39.6</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Compression </td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">10</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">11.7</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Max.power</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">4.11kw(5.6ps)/10,500rpm</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">5.14kw(7.0ps)/13,500rpm</td> </tr> <tr style="height: 25.5pt;" height="34"> <td style="height: 25.5pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="34">Max.torque</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">4.11N・m(0.42kg-m)/8,500rpm</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">4.41N・m(0.45kg-m)/10,500rpm</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Carburetor</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">PC09</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">PC20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Ignition </td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">CDI</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">CDI</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">fuel Capacity(L) </td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">6.2</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">6.2</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Clutch</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">Wet multi plate</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">Wet multi plate</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Transmission</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">5 speed </td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">6 speed </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">speed ratio </td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">4.437/3.583</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">4.437/3.583</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Frame</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">Diamond</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">Diamond</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">Brakes (FRNT)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(disk brake)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(disk brake)</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">(REAR)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(disk brake)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(disk brake)</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Wheels (FRNT)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">2.50-18 45L</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">2.50-18 45L</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">(REAR)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">2.50-18 45L</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">2.50-18 45L</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% aqua;" width="125" height="17">(FRNT)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(telescopic fork)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(telescopic fork)</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 94pt; text-align: right; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt; border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; padding: 0px; background: none repeat scroll 0% 0% rgb(204, 255, 255);" width="125" height="17">Suspension (REAR)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(swingarm)</td> <td style="width: 117pt; text-align: center; vertical-align: top; white-space: normal; color: windowtext; font-size: 10pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Arial; border-width: medium 0.5pt 0.5pt medium; border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; padding: 0px; background: none repeat scroll 0% 0% white;" width="156">(swingarm)</td> </tr> </tbody></table>
Why AHL is not introducing this in Pakistan ... it also available in Stranded Version ....
