[LEFT]HONDA ENGINE SERIES:A-series • B-series • B20A • C-series • D-series • E-series • E07A • F-series • F20C • G-series • H-series • J-series • K-series • L-series • Circle L Diesel • N-series Diesel • P-engine • R-series • HF120 Turbofan • VTEC • I-DSi • I-CDTi…
<U><FONT size=3>A-SERIES:ffice:office" /><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
A16A1
The A16A1 was a carburated 1.6 liter engine used in 1986-1989 Accords and Vigors outside the North American market. This engine was known as the EZ in 1984 and 1985, non-US Accords.
[/LEFT]
Specifications[LEFT]Carbureted
Displacement: 1,596 cc (97.4 cu in)
Bore: 80 mm (3.1 in)
Stroke: 79.5 mm (3.13 in)
Power:
88 hp (66 kW) @ 6000 rpm
91 ft·lbf (123 N·m) torque @ 3500 rpm<o:p></o:p>
A18A
<FONT face="Times New Roman">The A18A engine was the 1.8 liter engine found in 1984-1987 Honda Prelude in the ffice:smarttags" /><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com
</B>
[/LEFT]
Displacement: 1,829 cc (111.6 cu in)
Stroke: 91 mm (3.6 in)
Power:
110 hp (82 kW) @ 5800 rpm
112 ft·lbf (152 N·m) @ 3500 rpm
A20A
The A20A was available in both carbureted and fuel-injected versions. They were found in both Accords and Preludes throughout the 1980s.
A20A1 & A20A2
The A20A1 and A20A2 were the carbureted versions of the A20A engines. It was available in the 1984-1987 Honda Preludes as well as the 1982-1989 Accord DX and LX. They are the same engine, the only difference between them being that the A20A2 has no emissions components, so it has a slightly higher power output.
[/LEFT]
Specifications[LEFT]Exhaust: 4-1 Cast Manifold
Induction: Carbureted 2bbl Keihin ( Feedback Carb )
Displacement: 1,955 cc (119.3 cu in)
Bore: 82.7 mm (3.26 in)
Power (A20A1):
98 hp (73 kW)
109 ft·lbf (148 N·m) at 3500 rpm
A20A3 and A20A4
The A20A3 and A20A4 were the fuel injected versions of the A20A engines. They were run by Honda's PGM-FI system on a partial OBD-0 computer. The A20A4 gives a slightly higher power output because of not having emissions components. The A20A3 was offered in the 1984-1987 Honda Prelude 2.0Si, the 1989 Honda Accord SE-i, and the 1986-1989 Honda Accord LX-i.
[/LEFT]
Specifications[LEFT]PGM-FI
Bore:82.7 mm (3.26 in)
Stroke:91 mm (3.6 in)
Power:
1986-1987: 110 hp (82 kW) @ 5500 rpm & 114 ft·lbf (155 N·m) @ 4500 rpm
1988-1989: 120 hp (89 kW) @ 5500 rpm & 122 ft·lbf (165 N·m) @ 4000 rpm (12 valve)
B-SERIES:
B16
JDM B16A (First Generation)
[/LEFT]
The first VTEC engine Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).[LEFT]VTEC
Found in:
1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1990 JDM Honda CRX SiR (EF8) <o:p></o:p>
1989-1990 JDM Honda Civic SiR (EF9)
o <o:p></o:p>
Displacement: 1,595 cc (97.3 cu in) 1.6 liter
Compression: 10.2:1
Bore: 81.0 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod Length: 134 mm (5.3 in)
Rod/stroke ratio: 1.745
Power: 160 PS (118 kW; 158 hp) @ 7,600 rpm & 15.5 kg·m (152 N·m; 112 ft·lbf) @ 7,000 rpm
Redline: 8100 rpm
Transmission: S1/J1/YS1 (4.4 final drive), Y1 (4.266 final drive, cable clutch, optional LSD)
ECU code: PR3-003 (DA6/DA8), PW0-000 (EF8/EF9/DA6) <o:p></o:p>
ODB0
JDM B16A (Second Generation)
Found in:
1991-1994 JDM Honda Civic Sir/SiRII (EG6)
1991-1993 JDM Honda Civic Ferio SiR (EG9)
1992-1995 JDM Honda CRX Delsol SiR (EG2) <o:p></o:p>
1995-1998 JDM Honda Civic Sir/SiRII (EK4)
1995-1998 JDM Honda Civic Ferio Si (EK4)
o <o:p></o:p>
Compression: 10.4:1
Power: MT: 170 PS (125 kW; 168 hp) @ 7,800 rpm & 16.0 kg·m (157 N·m; 116 ft·lbf) @ 7,300rpm (AT: 160 PS (118 kW; 158 hp) @ 7,300 rpm & 15.6 kg·m (153 N·m; 113 ft·lbf) @ 6,500rpm)
Redline: 8200 rpm (AT: 7700 rpm)
Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
ECU code: P30 (EG2/EG6) <o:p></o:p>
ODB1/ODB2
B16B (Type R)VTEC
Found in:
[/LEFT]
1997-2000
JDM Civic Type R[EK9]
Compression: 10.8:1
Bore: 81 mm (3.2 in)
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.6 in)
Power: 136 kW (185 PS; 182 hp) @ 8200 rpm & 16.3 kg·m (160 N·m; 118 ft·lbf) @ 7500 rpm
Redline: 8400 rpm
Rev-limit: 9000 rpm
Transmission: S4C With Helical LSD (4.1 final drive, dual-synchromesh on 2nd, 3rd and 4th gears)
Vtec engagement @ 5800 rpm
ECU code: PCT
OBD-2B
· Note: This engine uses the same block as the Integra Type R (B18CR), which is taller than the B16a block (by approx 17mm), but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16.
[LEFT]
B16A1
VTEC
Found in:
Early Integra, CRX, Civic'1.6i-VT'(EE8)(EE9)
Displacement: Template:Convert/aa 1.6 liter (1595) <o:p></o:p>
Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
Compression: 10.2:1
Power: 150 hp (112 kW) @ 7600 rpm
Torque: 106 lb·ft (144 N·m) @ 7100 rpm <o:p></o:p>
Redline: 8000 rpm
Transmission: Y2
aluminium casting toma[/LEFT]
B16A2[LEFT]
VTEC
Found in:
1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
1992-1997 Honda Civic Del Sol EDM VTi (EG) <o:p></o:p>
1996-1997 Honda Civic Del Sol USDM "VTEC"
[/LEFT]
1999-2000
Honda Civic USDM
Si (EM1) <o:p></o:p>
1999-2000
Honda Civic CAN
SiR (EM1)
Compression: 10.2:1
Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
Transmission: Y21 or S4C
Redline...8000 rpm
Rev Limit...8450 rpm
VTEC Engagement...5,500 rpm
aluminium casting
B16A3
[LEFT]
VTEC
Found in:
1994-1995 Del Sol VTEC
Displacement 1,595 cc (97.3 cu in)
Power: 160 hp (119 kW) @ 7,600 rpm & 118 ft·lbf (160 N·m) @ 7,500 rpm
Redline: 8,200 rpm
Transmission: Y21
B16A4[/LEFT]
VTEC[LEFT]
[/LEFT]
Found in:
[LEFT]
[/LEFT]
1996-2000 Civic Si-RII (EK4)
Compression: 10.4:1
Power: 125.04 kW (170 PS; 168 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
Redline: 8200 rpm
Transmission: Y21
· Note: Only offered with SiRs with manual tranmissions.
[LEFT]
B16A5
VTEC
Found in:
1996-2000 Civic Si-RII (JDM version) (EK4) <o:p></o:p>
[/LEFT]
Compression: 10.4:1[LEFT]
[/LEFT]
[LEFT]Power: 130 kW (177 PS; 174 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
Redline: 8000 rpm
Transmission: Y21
· Note: Only offered with SiRs with automatic transmissions.
B16A6
[/LEFT]
[LEFT]VTEC
Found in:
1996-2000 Honda Civic - South <st1:place>Africa</st1:place> VTEC (EK)
Compression: 10.2:1
Power: 118 kW (160 PS; 158 bhp)
B17
B17A1
VTEC
[/LEFT]
[LEFT]
[/LEFT]
[LEFT]
[/LEFT]
[LEFT]
[/LEFT]
[LEFT]
[/LEFT]
[LEFT]
Displacement: 1,678 cc (102.4 cu in)
Bore: 81 mm (3.189 in)
Stroke: 81.4 mm (3.205 in)
Rod/Stroke Ratio: 1.63
Rod Length: 132.28 mm (5.208 in)
Compression: 9.7:1
Power: 160 hp (120 kW) @ 7600 rpm & 118 ft·lbf (159 N·m) @ 7000 rpm
Came equipped with the YS1 cable trans, which was different than other cable B-series transmissions as it has a different input shaft.
B18
B18A
The B18A is not considered part of the modern B-series family. This engine shares many characteristics with the B20A/B21 See Honda B20A engine.
[/LEFT]
[LEFT]
Found in:
[/LEFT]
[LEFT]
- 1986-1989 Accord Aerodeck LXR-S/LX-S (<st1:country-region><st1:place>Japan</st1:place></st1:country-region>)
1986-1989 Accord EXL-S/EX-S (<st1:country-region><st1:place>Japan</st1:place></st1:country-region>)
1986-1989 Vigor MXL-S (<st1:country-region><st1:place>Japan</st1:place></st1:country-region>)
[/LEFT]
[LEFT]Displacement: 1,834 cc (111.9 cu in)
Compression: 9.4:1
Stroke: 89 mm (3.5 in)
Dual Keihin Carbs
Power: 100 hp (75 kW) @ 6100 rpm & 128 lb·ft (174 N·m) @ 4700 rpm
Transmission: A2N5, E2N5
B18A1
NON -VTEC
Found in:
1990-1993 Acura Integra usdm "RS/LS/GS" (DA9, DB1)
Compression: 9.2:1
Rod Length: 137.01 mm (5.394")
Rod/Stroke Ratio: 1.54
Redline: 6500 rpm
Rev Limiter: 7200
Programmed fuel injection
Power: 90-91 Only: 130 bhp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
Power: 92-93 Only: 140 bhp (100 kW) @ 6300 rpm & 126 ft·lbf (171 N·m) @ 5000 rpm
Transmission: 90-91: A1,S1, cable
Transmission: 92-93: YS1, cable
B18B1
[/LEFT]
[LEFT]
- NON-VTEC
Found in:
Compression: 9.2:1
Power: 142 hp (106 kW) @ 6300 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
Redline: 6800 rpm
Rev Limit: 7200 rpm
Transmission: Y80/S80
[/LEFT]
[LEFT]
B18B4
NON-VTEC
Found in:
1996-2000 Honda Ballade 180i
Compression: 9.2:1
Rod Length: 137.01 mm (5.394 in)
Power: 4 hp
Redline: 7200 rpm
142 hp (106 kW) @ 7000 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
Transmission: Y80/4254245 [/LEFT]
JDM B18C[LEFT]
SPEC R
VTEC
Found in:
95-00 JDM Honda Integra Type R DC2
95-00 JDM Honda Integra Type R DB8
Rev-limit: 8600 rpm
Power: 200 PS (147 kW; 197 hp) @ 8000 rpm & 17.5 kg·m (172 N·m; 127 ft·lbf) @ 7500rpm (96 spec) 18.5 kg·m (181 N·m) @ 6200 rpm (98 spec)
Transmission: S80 with Helical LSD
S80 spec: J4D (96specR & 4.4 final drive), N3E (98specR & 4.785 final drive)
Displacement: 1,797 cc (109.7 cu in)
Compression: 11.1:1
Stroke: 87.2 mm (3.4 in)
Rod Length: 137.9 mm (5.4 in)
Rod/Stroke Ratio: 1.58
VTEC Engagement @ 5800 rpm
ECU code: P73-003 (96specR) P73-013 (98specR) <o:p></o:p>[/LEFT]
(Source: BMI Vol.1 Type R Legend)[LEFT]
SiR/GSR
VTEC
Found in:
93-95 JDM Honda Integra Si (DB8, DC2) <o:p></o:p>
95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
98-99 JDM Honda Integra SiR-G (DB8, DC2)
Identification: Black valve cover with dual runner intake manifold
Rev-limit: 8000 rpm
Power: 132.39 kW (180 PS; 178 bhp) @ 7200 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
Compression: 10.6:1
ECU code: P72 [/LEFT]
Highlights of B18C Spec R compared to standard B18C GSR[LEFT]
1. Camshaft - Wide-angled, high-lift, high-durability camshaft
2. Exhaust Valve Spring - High-lift, dual-layered spring
3. Spark plug - High-heat-type #7 platinum plug
4. Engine Stiffener - Aluminum die-cast, high-durability, one-piece type
5. Crankshaft - Full-counterweight, 8-weight, high-output, custom crankshaft
6. Connecting Rod - Custom TypeR rod, high-durability, lightened
7. Pistons - High-compression, low-friction, custom pistons
8. Inlet Valves - Lightened inlet valves
9. Intake Manifold - Custom tuning, single-port type.
10. Throttle Body - 62 mm (2.4 in) wide-mouth throttle body.
11. Inlet Valve Springs - High-lift, flat-surfaced, dual-layered spring
12. Port Buffing done by hand
13. Fastening of Connecting Rod done with micrometer. Even though all engine component parts are done by a micrometer and not eye balled.[/LEFT]
14. All stainless steel headers[LEFT]
B18C1
VTEC
Found in:
1994-2001 USDM Integra GS-R (DC2/DB8)
Compression: 10.0:1
Power: 170 hp (127 kW) @ 7600 rpm [/LEFT]
Torque: 128 lb·ft (174 N·m) @ 6200 rpm <o:p>[LEFT]
[/LEFT]
[LEFT]
- Redline: 8100 rpm (Fuel cut-off @ 8200 rpm)
VTEC Engagement @ 4400 rpm
Transmission: Y80(No LSD) 5-Speed Manual Transaxle
B18C2
VTEC
Found in:
1994-1999 Honda Integra VTi-R
AUDM Spec 1993-1999 Honda Integra VTi-R
Compression: 10:1
Power: 168 hp (125 kW) @ 7600 rpm
Torque: 128 lb·ft (174 N·m) @ 6200 rpm <o:p></o:p>
Redline: 8200 rpm
Fuel Cut: 8300 rpm
Transmission: Y80(No LSD) 5-Speed Manual Transaxle[/LEFT]
B18C3[LEFT]
VTEC
Found in:
1995-1998 Honda Integra Type R
Power: 193 PS (142 kW; 190 hp) @ 8200 rpm & 127 lb·ft (172 N·m) @ 7500 rp
B18C4
VTEC
Found in:
1996-2000 UK Civic 1.8i VTi 5-door Hatch (MB6)
1996-2000 UK Civic 1.8i VTi-S (Limited Edition) 5-door Hatch (MB6)
1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic 1.8i VTi 5-door Hatch (MB6)
VTEC engagement@4,400 rpm
IAB open@5,750 rpm
Compression: 10.0:1
Power: 169 hp (126 kW) @ 7600 rpm & 117 lb·ft (159 N·m) @ 6200 rpm
Limit: 8,100 rpm
Transmission: S9B w/Torsen LSD.
0/100 km/h : 7.9 seconds (8.5 Aerodeck)[/LEFT]
B18C5[LEFT]
VTEC
Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Compression: 10.6:1
Power: 197 hp (147 kW) @ 8000 rpm & 134 ft·lbf (182 N·m) @ 7300 rpm
Redline: 8400 rpm (Fuel cut-off @ 8500 rpm)
VTEC Engagement @ 6000 rpm
Transmission: S80 w/LSD
B18C6
VTEC
Found in:
1998-2001 Honda Integra <st1:country-region><st1:place>UK</st1:place></st1:country-region> and Euro Spec Type R
Type: 1.8 litre 16v DOHC 4 cylinder in-line
Compression: 11.1:1
Air intake diameter: 62 mm (2.4 in)
Power: 190 PS (140 kW; 187 hp) @ 7900 rpm & 131 lb·ft (178 N·m) @ 7300 rpm
Redline: 8400 rpm
Rev-limiter: 8700 rpm
Vtec engagement: 5700 rpm
Transmission: S80 w/LSD[/LEFT]
B18C7[LEFT]
VTEC
Found in:
1999 - 2001 Honda Integra Type R (<st1:country-region><st1:place>Australia</st1:place></st1:country-region>)
Power: 193 PS (142 kW; 190 hp) @ 8200 rpm & 127 lb·ft (172 N·m) @ 7500 rpm
B20
B20B
1996-1998 specs
NON-VTEC
Found in: USDM and JDM Honda CR-V, Honda Orthia
Displacement: 1,973 cc (120.4 cu in)
Power: 126 hp (94 kW)) @ 5400 rpm
Torque: 131 ft·lbf (178 N·m) @ 4300 rpm <o:p></o:p>
Rod length: 137 mm (5.4 in)
Compression: 8.8:1 or 9.2:1
Bore: 84 mm (3.3 in)
Redline: 6300 rpm
Fuel Consumption: City 9 km/L Hwy 14 km/L
B20B/B20Z
1999 - 2000 specs
NON-VTEC
Found in: USDM CRV as a B20Z, JDM Honda CR-V and Honda Orthia as a B20B
Power: 146 hp (109 kW)) @ 6200 rpm
Torque: 133 ft·lbf (180 N·m) @ 4500 rpm <o:p></o:p>
Rod length: 137 mm (5.394 in)
Compression: 9.6:1
Redline: 6700 rpm
Fuel Consumption: 14 km/L [/LEFT]
B20A/B21A[LEFT]
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
B Series Transmissions
Note: All B series Transmissions are interchangeable. YS1 casing can take S80 Internals or a hydraulic conversion kit can be used to operate hydraulic transmissions in cable operated models.
J1/S1
Found in: Integra XSI/RSI (DA6)
Type: Cable
1st: 3.230
2nd: 2.105
3rd: 1.458
[/LEFT]
4th: 1.00 [LEFT]
</o:p>
[/LEFT]
[LEFT]
FD: 4.400
S1/YS1
Found in: 1990-93 USDM Integra LS/RS (DA)
Type:cable
1st: 3.230
2nd: 1.901
3rd: 1.269
4th: 0.966
5th: 0.742
R: 3.000
FD: 4.266
Y1
Found in: CRX/Civic (optional LSD)
Type: Cable
1st: 3.166
2nd: 2.052
3rd: 1.416
4th: 1.102
5th: 0.870
R: 3.000
FD: 4.266
YS1
Found in: Integra 92-93 XSI/RSI (DA6, DA9)
Type: Cable
1st: 3.307
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.880
R: 3.000
FD: 4.400
S80
Found in: Integra Type R 98+ (LSD)
Type: Hydraulic
1st: 3.231
2nd: 2.105
3rd: 1.458
4th: 1.034
5th: 0.787
R: 3.000
FD: 4.785
S80/Y80
Found in: JDM SiR-G (optional LSD) / 94+ USDM GS-R (no LSD)
Type: Hydraulic
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
R: 3.000
FD: 4.400
S9B
Found in: EDM UKDM MB6 (LSD)
Type: Hydraulic
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.848
R: 3.000
FD: 4.266
Y21/Y80/S80/S4C
Found in:
JDM 96-97 Integra R(LSD)
JDM Civic R EK9
JDM Civic SiR [EK4, EG6]
JDM CR-X DEL SOL SIR (EG2)(optional LSD)
USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) <o:p></o:p>
Type: Hydraulic
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
R: 3.000
FD: 4.400
B20A,B20A1
[/LEFT]
(16-Valve, 4 Cylinder, DOHC, PGM-FI)[LEFT]"Honda" logo in center of valve cover - Filler cap on left side of cover.
Found in:
Serial numbers 1000001~, 1500001~ and 1550001~
1985-1986 Honda Prelude Non-U.S. <o:p></o:p>
1985-1986 Honda Accord Non-U.S.
1985-1986 Honda Vigor Non-U.S. <o:p></o:p>
Serial numbers 1600001~ and 1640001~
1987-1989 Honda Vigor Non-U.S. <o:p></o:p>
Displacement: 1958 cc
bore: 81 mm (3.2 in)
stroke: 95 mm (3.7 in)
Compression: 9.4:1; 9.5:1
Power:
(JDM GOLD TOP B20A 1986-1987) 160 hp (119 kW) @ 6300 rpm & 137 lb.ft (186 N·m) @ 4000 rpm, using PH3 ECU
(JDM BLACKTOP B20A 1988-1989) 160 hp (119 kW) @ 6200 rpm & 137 lb.ft (186 N·m) @ 4000 rpm, using PH3 ECU (Some think this engine have same spec as black top from 88-91 prelude, but this is not. This engine is still 160 hp. just like the gold top)
(EDM, B20A1 Gold Top) 137 hp (102 kW) @ 6000 rpm & 127 lb.ft (172 N·m) @ 4000 rpm, using PJ5(602,603,752),PJ7,PH3 ECU w vac. advance
Transmission: B2K5(86-87), F2K5(88-89)
B20A
This is for the B20a that came in 88-91 Preludes, not the same motor as listed above. (16-Valve, 4 Cylinder, DOHC, PGM-FI)
- Found in:
- 1988-1991 Honda Prelude Non-U.S. <o:p></o:p>
- Power: 143 hp (107 kW) @ 6000 rpm
- Torque: 128tq @ 4500 rpm
- Compression ratio: 9.4:1
- B20A2
[/LEFT]
(16-Valve, 4 Cylinder, DOHC, PGM-FI)[LEFT]Found in:
1987-1989 Honda Accord Non-U.S.
Power: 142 hp (106 kW) @ 6200 rpm
B20A3
[/LEFT]
(12-valve, SOHC, dual side-draft carburetors)[LEFT]Found in:
1988-1990 Honda Prelude 2.0 S
Power: 104 hp (78 kW) @ 5800 rpm (MT)With cata, 115 hp (86 kW) @ 5800 rpm without cata
Torque: 111 lb·ft (150 N·m) @ 4000 rpm <o:p></o:p>
It was PGM-CARB microprocesor controlled (pk-1)
B20A4
[/LEFT]
(12-Valve, SOHC, dual side-draft carburetors)[LEFT]Found in:
B20A5
(16-valve, DOHC, PGM-FI)
- Found in:
1988-1991 Honda Prelude 2.0Si
- Power: 135 hp (101 kW) @ 6200 rpm
- Torque: 127 lb·ft (172 N·m) @ 4000 rpm <o:p></o:p>
- Engine cc: 1958.14
- Cylinder cc: 489.535
- Deck cc: 13.885
- Head cc: 47.3
- Compression Ratio: 9.0:1
B20A6
[/LEFT]
(16-Valve, DOHC, PGM-FI)[LEFT]Found in:
1988-1991 Honda Prelude Non-U.S. <st1:country-region><st1:place>New Zealand</st1:place></st1:country-region>, and Australian Domestic Market
142 hp (106 kW)@6000 rpm 174 Nm@4500 rpm KY model is one of them
B20A7
[/LEFT]
1988-1991 Honda Prelude Non-U.S. <st1:country-region><st1:place>UK</st1:place></st1:country-region>, <st1:country-region><st1:place>France</st1:place></st1:country-region>, <st1:place>ffice:smarttags" /><st1:City>Holland</st1:City>, <st1:country-region>Norway</st1:country-region></st1:place>, <st1:country-region><st1:place>South Africa</st1:place></st1:country-region>
Power 150 hp (112 kW)@6000 rpm
132tq (180 Nm) @ 5500rpm
Compression ratio 10.5:1
B20A8
[/LEFT]
1988-1991 Honda Prelude Non-U.S. Russian, Swedish Domestic Market
1988-1989 Honda Accord Non-U.S.
Power 133 hp (99 kW)
B20A9
[/LEFT]
1990-1991 Honda Prelude Non-U.S. Finland, German, <st1:country-region><st1:place>Norway</st1:place></st1:country-region>, <st1:country-region><st1:place>Netherlands</st1:place></st1:country-region>, <st1:country-region><st1:place>Russia</st1:place></st1:country-region>, <st1:country-region><st1:place>Argentina</st1:place></st1:country-region>
Power 140 hp (104 kW)@6000 rpm
Torque 129tq (175 Nm) @ 4500rpm
B21A
[/LEFT]
(16-valve, DOHC, PGM-FI)[LEFT]Found in:
1990-1991 Honda Prelude Si States
Very rare, it was only produced for the "Si States" models in <st1:country-region><st1:place>Japan</st1:place></st1:country-region>
Power: 145 hp (108 kW)
Torque: 186 N·m (137 lbf·ft) <o:p></o:p>
Compression Ratio 9.4.1
B21A1
[/LEFT]
1990-1991 Honda Prelude SI USDM
1990-1991 Honda Prelude SR Canadian Market
Power: 140 hp (104 kW) @5800 rpm
Torque: 135 lb·ft (183 N·m) @5000 rpm <o:p></o:p>
Engine cc: 2056.03
Cylinder cc: 514.0075
Deck cc: 10.191
Head cc: 51.0
Compression Ratio: 9.4:1
C-SERIES:
C20A
The SOHC C20A is a 2.0 L version, producing 145 hp (108 kW).
[/LEFT]
Applications; <st1:country-region><st1:place>Japan</st1:place></st1:country-region> only:[LEFT]1985 Honda Legend
The C20AT was a turbocharged version, producing 190 hp (140 kW).
[/LEFT]
Applications; <st1:country-region><st1:place>Japan</st1:place></st1:country-region> only:[LEFT]1989 Honda Legend
o <o:p></o:p>
NOTE: Honda made a variable geometry turbo equipped Legend marketed in the Japanese Domestic Market. The turbo equipped engine was the C20AT engine and are extremely rare. Honda pioneered variable geometry turbo chargers. The wing turbo as Honda called them, were controlled by an 8 bit processor ecu and they were constantly adjusting. Basically, at low speeds the wings would be nearly closed to speed and direct exhaust pressure precisely on the turbine wheel. At cruise speeds, the wings would be open and it would act like a much larger turbo to increase fuel economy. This car was quick and powerful, but the price premium over the standard Legend was too much for most so the car disappeared. This was one of the only production Hondas ever turbocharged from the factory, along with the new Acura RDX and the older Honda City's.
C25A
The SOHC C25A is a 2.5 L version, producing 165 hp (123 kW).
[/LEFT]
Applications; <st1:place>North America</st1:place> Only:[LEFT]1986-1987 Acura Legend <st1:City><st1:place>Sedan</st1:place></st1:City>, 151 hp (113 kW)
1986-1988 Rover 825 <st1:City><st1:place>Sedan</st1:place></st1:City>, 151 hp (113 kW) <st1:country-region><st1:place>UK</st1:place></st1:country-region> and <st1:place>Europe</st1:place> (sold in US as STERLING)
C27A
The SOHC C27A is a 2.7 L version, producing 170 hp, (127 kW).
Applications; non-North <st1:country-region><st1:place>America</st1:place></st1:country-region>:
[/LEFT]
· <o:p></o:p>[LEFT]1987-1990 Honda Legend Coupe, 176 hp
1987-1990 Honda Legend Saloon, 176 hp
Applications; <st1:place>North America</st1:place>:
SOHC non-VTEC
1987 Acura Legend Coupe , 161 hp (120 kW)
1988-1990 Acura Legend, 161 hp (120 kW)
1995-1997 Honda Accord, 170 hp (128 kW) For this particular vehicle the engine was updated with a more efficient intake manifold.
1989-1991 Rover 827/Sterling/Vitesse, 177 hp (non catalyst)<st1:country-region><st1:place>UK</st1:place></st1:country-region> and <st1:place>Europe</st1:place> (sold in US as STERLING Brand)
1990-1991 Rover 827/Sterling/Vitesse, 168 hp (catalyst) <st1:country-region><st1:place>UK</st1:place></st1:country-region> and <st1:place>Europe</st1:place> (sold in US as STERLING Brand until 1991)
1991-1995 Rover 827/Sterling/Coupe, 168 hp <st1:country-region><st1:place>UK</st1:place></st1:country-region> and <st1:place>Europe</st1:place>
C30A
The DOHC VTEC C30A is a 3.0 L version, producing 201 kW (270 bhp) and 285 N·m (210 ft·lbf) of torque. The engine was the first in the <st1:country-region><st1:place>US</st1:place></st1:country-region> to utilize Honda's proprietary VTEC variable-valve timing system, which adjusts cam lift and duration depending on engine RPM and throttle position. VTEC allows the C30A to produce a high maximum power level while maintaining a relatively flat torque curve.
The C30A also made use of titanium connecting rods, which was another first in a mass-production vehicle. The lightweight rods allowed a higher RPM to be achieved while maintaining the strength of traditional steel rods. The C30A block is an open-deck design made from an aluminum alloy with cylinders sleeved in ductile iron. The heads are a twenty-four valve, dual-overhead cam (DOHC) design and contain the VTEC mechanism, which is actuated by oil pressure. For maximum performance, the C30A uses a direct ignition system, with individual coils positioned directly over each cylinder spark plug.
Due to its DOHC layout and its lighweight rotating assembly, the C30A is capable of reliable high RPM operation. Factory redline is 8000RPM and balanced/blueprinted versions of the engine can easily reach 9000RPM with little to no reliability issues.
Due to its complexity, cost and use of exotic materials, the C30A was used exclusively on Honda's NSX supercar. For NSX's equipped with a 4-speed automatic transmission,
Honda used a slightly less powerful version of the C30A, which utilized less aggressive cam timing and produced 252 bhp.
An advanced version of this engine exists (though not in a production form) that campaigned briefly in the 2004 Japanese SuperGT racing series (see All Japan Grand Touring Car Championship) by the factory-supported Team Honda Racing group in highly modified GT-spec NSXs. This engine has various upgrades and modifications by Mugen and is the first turbo-charged Honda engine used in the series (prior to 2003, the GT-spec NSXs used a highly advanced, naturally-aspirated variant of the C32B engine). Though the exact performance figures are kept secret, it is rumored to output more than 500 bhp.
[/LEFT]
Applications:[LEFT]1991-1996 Honda NSX 5-Speed Manual Transmission
1991-2005 Honda NSX 4-Speed Automatic Transmission
C32A
The C32A is a 3.2 L version. The SOHC depending on model year, produces 200 and 230 hp (175 kW).
[/LEFT]
Applications; <st1:place>North America</st1:place> Only:[LEFT]C32A1 - SOHC USDM - 200 hp (155 kW)
1991-1995 Acura Legend sedan
1991-1992 Acura Legend coupe
C32A6 - SOHC USDM - 200 hp (155 kW)
1996-1998 Acura 3.2TL
C32A5 - Also known as the "Type-II" - Uses a higher flowing intake manifold and slightly more aggressive camshaft - SOHC USDM - 230 hp (170 kW) at 206 ft·lbf (279 N·m)
1994-1995 Acura Legend GS sedan
1993-1995 Acura Legend LS and L coupe
1995-1998 Honda Inspire/Honda Sabre
C32B
The C32B is a highly tuned DOHC V6 used in the Honda NSX, which produces 290 hp (216 kW) and 224 lbf·ft (304 N·m). The engine is essentially an update to the C30A and does not share commonality with the C32A. Honda increased displacement to 3.2 L (~195 cu in) through the use of larger 93 mm (3.7 in) pistons over the 90 mm (3.5 in) used in the C30A. To accommodate the larger pistons, Honda used an advanced metallurgical technique on the cylinders called Fiber Reinforced Metal (FRM), in which an ultra lightweight alumina-carbon fiber is cast into the traditional aluminum alloy for enhanced rigidity. This process allowed thinner cylinder walls to be used while providing
acceptable cooling characteristics. The C32B also used 32 mm (1.3 in) intake valves, which are 1 mm (0.04 in) larger than those in the C30A.
[/LEFT]
Applications:[LEFT]1997-2005 Honda NSX 6-Speed Manual Transmission
C35A
The C35A is a SOHC and carries the largest displacement of the C series at 3.5 L (~214 cu in).
[/LEFT]
Applications:[LEFT]C35A - SOHC - 210–225 hp (155–170 kW)
1996-2004 Acura 3.5RL (US/Canada)
1996-2004 Honda Legend (non-US/Canada
D-SERIES:
D12 Series Engines (1.2 Litre)<o:p></o:p>
[/LEFT]
D12A<o:p></o:p>[LEFT]Found in: <o:p></o:p>
1988-1991 Civic EX(Japanese Market) <o:p></o:p>
Displacement : 1,187 cc (72.4 cu in) <o:p></o:p>
Bore and Stroke : 72.0 mm × 76.0 mm (2.83 in × 2.99 in) <o:p></o:p>
Compression : 9.5:1 <o:p></o:p>
Power : 63 hp (47.0 kW, 63.9 ps) @ 6500 rpm <o:p></o:p>
Torque : 65 ft·lbf (8.99 kg/m, 88.1 Nm) @ 4000 rpm <o:p></o:p>
Valvetrain : SOHC (4 valves per cylinder) <o:p></o:p>
Fuel Control : Single Carburetor <o:p></o:p>
There are some locally distributed units that start with JHM, these are the 1,200 cc (73.2 cu in) EF sold in 1991. all 1000+ units were imported from Japan (SKD) <o:p></o:p>
D13 Series Engines (1.3 Litre)<o:p></o:p>
[/LEFT]
D13B1<o:p></o:p>
1988-1991 Honda Civic EC (European Market) <o:p></o:p>
Displacement : 1,343 cc (82.0
cu in) <o:p></o:p>
Bore and Stroke : 75.0 mm × 76.0 mm (2.95 in × 2.99 in) <o:p></o:p>
Power : 75 hp (55.0 kW, 76.0 ps) @ 6300 rpm <o:p></o:p>
Torque : 75.2 ft·lbf (10.3 kg/m, 102 Nm) @ 3100 rpm <o:p></o:p>
D13B2<o:p></o:p>Found in: <o:p></o:p>
1992-1995 Honda Civic DX (European Market) <o:p></o:p>
Displacement : 1,343 cc (82.0 cu in) <o:p></o:p>
Compression : 9:1 <o:p></o:p>
Power : 74.9 hp (55.9 kW, 76.0 ps) @ 6300 rpm <o:p></o:p>
Torque : 75.2 ft·lbf (10.4 kg/m, 102 Nm) @ 3100 rpm <o:p></o:p>
D13B4<o:p></o:p>Found in: <o:p></o:p>
1996-2002 Honda City LXi/EXi/DX <o:p></o:p>
Displacement : 1,300 cc (79.3 cu in) <o:p></o:p>
Compression : 9.75:1 <o:p></o:p>
Power : 95 hp (70.8 kW, 96.3 ps) @ 6500 rpm <o:p></o:p>
Torque : 94 ft·lbf (12.8 kg/m, 127 Nm) @ 4200 rpm <o:p></o:p>
Valvetrain : SOHC (4 valves per cylinder) - 16 valve <o:p></o:p>
Fuel Control : <st1:place>ffice:smarttags" /><ST1:PlaceType>Multi-point</ST1:PlaceType> <ST1:PlaceName>fuel Injection</ST1:PlaceName></st1:place>, PGM-FI <o:p></o:p>
D13B7<o:p></o:p>Found in: <o:p></o:p>
1998-2001 Honda Logo 5D <o:p></o:p>
Displacement :? <o:p></o:p>
Bore and Stroke : ? <o:p></o:p>
Compression : 8:1 <o:p></o:p>
Power : ? hp (? kW, ? ps) @ 6800 rpm <o:p></o:p>
Torque : ? ft·lbf (? kg/m, ? Nm) @ 6500 rpm <o:p></o:p>
Fuel Control : <st1:place><ST1:PlaceType>Multi-point</ST1:PlaceType> <ST1:PlaceName>fuel Injection</ST1:PlaceName></st1:place>, PGM-FI <o:p></o:p>
D13C<o:p></o:p>Found in: <o:p></o:p>
1989-1994 Honda City CE, CE Fit, CE Select, CG, CR-i, CR-i limited, CZ-i, New Fit (Japanese Market)
<o:p>[LEFT]
Displacement : ? <o:p></o:p>Bore and Stroke : ? <o:p></o:p>Compression : 10:1 <o:p></o:p>Power : ? hp (? kW, ? ps) @ ? rpm <o:p></o:p>Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm <o:p></o:p>Valvetrain : SOHC (? valves per cylinder) <o:p></o:p>Fuel Control : <st1:place>ffice:smarttags" /><ST1:PlaceType>Multi-point</ST1:PlaceType> <ST1:PlaceName>fuel Injection</ST1:PlaceName></st1:place>, PGM-FI <o:p></o:p>D13C ?<o:p></o:p>Found in: <o:p></o:p>1989-1994 Honda City (Japanese Market) <o:p></o:p>Displacement : 1,343 cc (82.0 cu in) <o:p></o:p>Bore and Stroke : 75.0 mm × 76.0 mm (2.95 in × 2.99 in) <o:p></o:p>Compression : 9.6:1 <o:p></o:p>Power : 100 ps (73.55 kW) / 6500 rpm <o:p></o:p>Torque :11.6 kg*m (113.76 N*m) / 5500 rpm <o:p></o:p>Valvetrain : SOHC (4 valves per cylinder) <o:p></o:p>Fuel Control : PGM-FI <o:p></o:p>D14 Series Engines (1.4 Litre)<o:p></o:p>
[/LEFT]
D14A1<o:p></o:p>
1987-1991 Honda Civic GL and 1990 CRX (European Market) <o:p></o:p>
Displacement : 1,396 cc (85.2 cu in) <o:p></o:p>
Bore and Stroke : 75.0 mm × 79.0 mm (2.95 in × 3.11 in) <o:p></o:p>
Compression : 9.3:1 <o:p></o:p>
Power : 90 hp (67.1 kW, 91.3 ps) @ 6300 rpm <o:p></o:p>
Torque : 83 ft·lbf (11.5 kg/m, 112 Nm) @ 4500 rpm <o:p></o:p>
Fuel Control : Dual Carburetor <o:p></o:p>
D14A2<o:p></o:p>
1995-1996 Honda Civic MA8 (European Market) <o:p></o:p>
Compression : 9.2:1 <o:p></o:p>
Power : 89 hp (66.4 kW, 90.2 ps) @ 6100 rpm <o:p></o:p>
Torque : 86 ft·lbf (11.9 kg/m, 117 Nm) @ 5000 rpm <o:p></o:p>
</o:p></o:p>[LEFT]
[/LEFT]
D14A3<o:p></o:p>[LEFT]Found in: <o:p></o:p>
1996-1999 Honda Civic 1.4i EJ9 (European Market) <o:p></o:p>
Compression : 9.1:1 <o:p></o:p>
Ecu code: P3X <o:p></o:p>
Power : 75 hp (55.9 kW, 76.0 ps) @ 5700 RPM also 90 hp <o:p></o:p>
Torque : 82.60 ft·lbf (11.42 kg/m, 112 Nm) @ 3000 rpm <o:p></o:p>
Valvetrain : SOHC (4 valves per cylinder), non VTEC <o:p></o:p>
Redline : 6800 RPM <o:p></o:p>
Fuel cut: 7200 RPM <o:p></o:p>
Fuel Control : DPFI Dual point fuel injection, 1+3 2+4 injectors thrown together <o:p></o:p>
Transmission: S40 <o:p></o:p>
D15 Series Engines (1.5 Liters)<o:p></o:p>
[/LEFT]
D15A1<o:p></o:p>[LEFT]Found In: <o:p></o:p>
1985-1987 Honda CRX <o:p></o:p>
Displacement : 1,488 cc <o:p></o:p>
Bore and Stroke : 74.0 x 86.5 mm <o:p></o:p>
Power : 76 hp @ 5500 rpm <o:p></o:p>
Torque : 84 ft-lbf @ 3500 rpm <o:p></o:p>
Valvetrain : SOHC (3 valves per cylinder), non VTEC <o:p></o:p>
Fuel Control : OBD-0 12/v carb <o:p></o:p>
Redline : 6500 rpm <o:p></o:p>
Economy : 31/38 mpg <o:p></o:p>
Head code : EW-1 <o:p></o:p>
ECU : - <o:p></o:p>
Transmission : DA48 <o:p></o:p>
Gear ratios : 2.38/ 1.76/ 1.18/ 0.85/ 0.71 <o:p></o:p>
Final drive ratio : 4.27 <o:p></o:p>
D15A2<o:p></o:p>
Found in : <o:p></o:p>
1984-1987 Honda CRX HF Grifin <o:p></o:p>
Displacement : 1,342 cc <o:p></o:p>
Compression : 10.0:1 <o:p></o:p>
Power : 76 hp @ 5550 rpm <o:p></o:p>
Torque : 73 ft-lb @ 3500 rpm *** Redline : 6000 rpm
Valvetrain : OBD-0 8/v EFI <o:p></o:p>
Economy : 49/54 mpg <o:p></o:p>
Gear ratios : 2.92/?/?/?/0.65 <o:p></o:p>
Final drive ratio : 3.58 <o:p></o:p>
D15A3<o:p></o:p>
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ) <o:p></o:p>
Displacement : 1,488 cc (90.8 cu in) <o:p></o:p>
Bore and Stroke : 74 mm × 86.5 mm (2.9 in × 3.41 in) <o:p></o:p>
Compression : 8.7:1 <o:p></o:p>
Power : 91 hp (67 kW, 59.2 ps) @ 5500 rpm <o:p></o:p>
Torque : 93 ft·lbf (12.9 kg/m, 126 Nm) @ 4500 rpm <o:p></o:p>
Valvetrain : SOHC (3 valves per cylinder ) <o:p></o:p>
Fuel Control : PGM-FI2 <o:p></o:p>
D15A4<o:p></o:p>
Needs more info<o:p></o:p>
D15A5<o:p></o:p>
Needs more info<o:p></o:p>[/LEFT]
D15B VTEC<o:p></o:p>
Found in : <o:p></o:p>1991-1995 Honda CRX Del Sol VXi EG1 (Japanese Market) <o:p></o:p>1991-1995 Honda Civic VTi EG4 (Japanese Market) <o:p></o:p>1991-1995 Honda Civic VTi EG8 (Japanese Market) <o:p></o:p>1997 Honda Civic Ferio Vi EK3 (Japanese Market) <o:p></o:p>Displacement : 1,493 cc (91.1 cu in) <o:p></o:p>Bore and Stroke :75,0×84,5 mm <o:p></o:p>Rod Length : 137 mm <o:p></o:p>Rod/Stroke : 1.62 <o:p></o:p>Compression : 9,2:1 <o:p></o:p>Power : 130 hp (95.4 kW, 130 ps) @ 6600 rpm <o:p></o:p>Torque : 106 ft·lbf (14.1 kg/m, 138 Nm) @ 5200 rpm <o:p></o:p>Redline : 7200 rpm <o:p></o:p>Rev-limiter : 7500 rpm <o:p></o:p>Valvetrain : SOHC VTEC (4 valves per cylinder) <o:p></o:p>VTEC Switchover : 5500 rpm <o:p></o:p>Head Code : P08 <o:p></o:p>Piston Code: P08-010 <o:p></o:p>Fuel Control : OBD-1 PGM-FI <o:p>
ECU : P08 <o:p></o:p>
D15B<o:p></o:p>
1988 Honda CRX 1.5X (rare) <o:p></o:p>
1990 Honda Civic 25XXT Formula (Japanese Market) <o:p></o:p>
Honda Civic Ferio MX (Japanese Market) <o:p></o:p>
1998-2001 Honda Capa GA4 (Japanese Market) <o:p></o:p>
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in) <o:p></o:p>
Power : 130 hp (96.9 kW, 105 ps) @ 6500 rpm <o:p></o:p>
Torque : 115 ft·lbf (13.2 kg/m) @ 4500 rpm <o:p></o:p>
Rev limiter : 7900 rpm <o:p></o:p>
Fuel Control : Dual Carburetor/fuel injected <o:p></o:p>
D15B1<o:p></o:p>
1988-1991 Honda Civic Hatchback <o:p></o:p>
Power : 70hp (52.2 kW, 71.0 ps) @ 5500 rpm <SUP>[1]</SUP> <o:p></o:p>
Torque : 83ft·lbf (11.4 kg/m, 112 Nm) @ 3000 rpm <SUP>[1]</SUP> <o:p></o:p>
Valvetrain : SOHC (4 valves per cylinder) NON-VTEC <o:p></o:p>
Head Code : PM3 <o:p></o:p>
Fuel System : Dual Point injection <o:p></o:p>
ECU Code: PM9 <o:p></o:p>
D15B2<o:p></o:p>
1988-1991 Honda Civic GL/DX/LX <o:p></o:p>
1988-1991 Honda Civic Wagon Wagovan/DX <o:p></o:p>
1988-1991 Honda CRX DX <o:p></o:p>
1992-1995 Honda Civic LSi Hatch/Saloon (European Market) <o:p></o:p>
1992-1995 Honda Civic DXi Hatch/Saloon (European Market) <o:p></o:p>
1990-1995 Honda Concerto (European Market) <o:p></o:p>
Rod Length : 134 mm <o:p></o:p>
Power : 92 hp (68.6 kW, 93.3 ps) @ 6000 rpm
Torque : 88 ft·lbf (12.2 kg/m, 119 Nm) @ 4500 rpm <o:p></o:p>
<st1:place>Cam</st1:place> Gear : 37 tooth <o:p></o:p>
Piston Code : PM3 <o:p></o:p>
Fuel Control : OBD-O DPFI/Obd-1 DPFI <o:p></o:p>
Redline : 6500 rpm, 7000 rpm rev limiter <o:p></o:p>
ECU Code: PM5/P04 <o:p></o:p>
D15B3<o:p></o:p>
1988-1995 Honda Civic Shuttle GL <o:p></o:p>
1992-1995 Honda Civic LX (NZ model) <o:p></o:p>
1988-1991 Honda Civic LX (NZ model) <o:p></o:p>
1992-1995 Honda Civic EX (SA model) <o:p></o:p>
Compression : 9.9:1 <o:p></o:p>
Power : 93 hp (69 kW, ? ps) @ 6000 rpm <o:p></o:p>
Torque : ? ft·lbf (? kg/m, 121 Nm) @ 4500 rpm <o:p></o:p>
<st1:place>Cam</st1:place> Gear : 38 tooth <o:p></o:p>
Fuel Control : Carburetor <o:p></o:p>
D15B4<o:p></o:p>
1989-1991 Honda Civic GL (Australian Market) <o:p></o:p>
Power : 96.5 hp (72 kW) @ 5200 rpm <o:p></o:p>
Torque : 90 ft·lbf (12.4 kg/m, 122 Nm) @ 3800 rpm <o:p></o:p>
D15B6<o:p></o:p>
1988-1991 Honda Crx HF <o:p></o:p>
Power : <o:p></o:p>
['88-'89] 62 bhp (46.23 kW, 62.86 ps) @ 4400 rpm
['90-'91] 72 bhp (53.7 kW, 73.0 ps) @ 4500 rpm <o:p></o:p>
Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2200 rpm <o:p></o:p>
Valvetrain : 8-Valve SOHC <o:p></o:p>
Fuel Control : OBD-0 MPFI <o:p></o:p>
Head Code : PM-8 <o:p></o:p>
D15B7<o:p></o:p>
1992-1995 Honda Civic CX (Canadian model) <o:p></o:p>
1992-1995 Honda Civic DX/LX <o:p></o:p>
1993-1995 Honda Civic <ST1:State><st1:place>del</st1:place></ST1:State> Sol S <o:p></o:p>
1992-1995 Honda Civic LSi Coupe (European Market) <o:p></o:p>
Power : 102 hp (76.1 kW, 109 ps) @ 5900 rpm (102 hp @ 5900 rpm in <st1:country-region><st1:place>U.S.</st1:place></st1:country-region>) <o:p></o:p>
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 5000 rpm <o:p></o:p>
<st1:place>Cam</st1:place> Gear: 38 Tooth <o:p></o:p>
Fuel Control : OBD-1 MPFI <o:p></o:p>
ECU Code: P06 <o:p></o:p>
D15B8<o:p></o:p>
1992-1995 Honda Civic CX (<st1:country-region><st1:place>U.S.</st1:place></st1:country-region> model) <o:p></o:p>
Displacement : 1,500 cc (91.5 cu in) <o:p></o:p>
Power : 70 hp (52.2 kW, 71.0 ps) @ 4500 rpm <o:p></o:p>
Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2800 rpm <o:p></o:p>
Valvetrain : SOHC (2 valves per cylinder) <o:p></o:p>
Fuel Control : OBD-1 MPFI. <o:p></o:p>
D15Z1<o:p></o:p>
VTEC-E <o:p></o:p>
1992-1995 Honda Civic VX <o:p></o:p>
1992-1995 Honda Civic VEi (European Market) <o:p></o:p>
Bore and Stroke :Template:Convert/p;y67' ipij9x <o:p></o:p>
Power : 90 hp (67.1 kW, 91.3 ps) @ 5600 rpm (92 hp @ 5500 rpm USDM) <o:p></o:p>
Torque : 98 ft·lb (13.5 kg/m, 133 Nm) @ 4800 rpm (97 ft·lb @ 30000 rpm USDM) <o:p></o:p>
Valvetrain : SOHC VTEC-E (USDM- Lean Burn Federal Emissions 49 State) (=-0-09-4 valves per cylinder depending on RPM) <o:p></o:p>
VTEC Switchover : 2500 rpm <o:p></o:p>
ECU Code : P07 <o:p></o:p>
D15Y3 Sohc Non vtec 2001-2006 civic (<st1:place>africa</st1:place>, <st1:City><st1:place>dubai</st1:place></st1:City>) power: 105hp (4200rpm)<o:p></o:p>
[LEFT]
[/LEFT]
D15Z4<o:p></o:p>1996-2000 Civic Exi and SA Ballade & Civic 150i <o:p></o:p>
Power : 90 hp (67.1 kW, 91.3 ps) or 105 hp (77 kW) @ 5800 rpm <o:p></o:p>
Torque : 99–103 ft·lbf (14 kg/m, 134-140 Nm) :confirm? @ 4200 rpm <o:p></o:p>
D15Z6<o:p></o:p>SOHC VTEC <o:p></o:p>
1995-2000 Honda Civic 1.5 iLS (European Market) <o:p></o:p>
Power : 114 hp (84 kW) @ 6500 rpm <o:p></o:p>
Torque : 99 ft-lb (134 Nm) @ 5400 rpm <o:p></o:p>
VTEC Switchover : depending on load, max ~3500 rpm in 5th gear <o:p></o:p>
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm) <o:p></o:p>
Fuel Control : OBD2a PGM-FI MPFI <o:p></o:p>
Ecu Code : P2Y <o:p></o:p>
Head Code : P2J <o:p></o:p>
D15Z7<o:p></o:p>3-stage VTEC <o:p></o:p>
Found in: <o:p>
1996-1999 Honda Civic VTi EK3 and Ferio Vi <o:p></o:p>
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm <o:p></o:p>
Torque : 102 ft·lbf (14.2 kg/m, 139 Nm) @ 5300 rpm <o:p></o:p>
VTEC Switchover : 5800-6200 rpm <o:p></o:p>
Fuel Control : OBD-2 MPFI <o:p></o:p>
ECU Code : P2J <o:p></o:p>
hgh<o:p></o:p>
D15Z8<o:p></o:p>
VTEC-E <o:p></o:p>
1997-2000 Honda Civic LS (European Market) <o:p></o:p>
Power : 114 hp (85.0 kW, 116 ps) @ 6500 rpm <o:p></o:p>
Torque : error?: 95–99 ft·lbf (13–14 kg/m, 128-134 Nm) :confirm? @ 4500 rpm <o:p></o:p>
Head Code : P2J P2M <o:p></o:p>
ECU Code : P9L <o:p></o:p>
VTEC Switchover : 2500 rpm(3500rpm in 5th gear) <o:p></o:p>
Valvetrain : SOHC VTEC-E (4 valves per cylinder) <o:p></o:p>
Fuel Control : OBD2 MPFI <o:p></o:p>
D16 Series Engines (1.6 Liters)<o:p></o:p>
D16A1<o:p></o:p>Found in: <o:p></o:p>
1986-89 Acura Integra (<st1:country-region><st1:place>USA</st1:place></st1:country-region>) <o:p></o:p>
Displacement : 1,590 cc (97 cu in) <o:p></o:p>
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in) <o:p></o:p>
Valvetrain : DOHC (4 valves per cylinder) <o:p></o:p>
1986-1987 <o:p></o:p>
Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm <o:p></o:p>
Piston Code: PG6 <o:p></o:p>
1988-1989 <o:p></o:p>
Compression : 9.5: 1 <o:p></o:p>
Power : 118 hp (88.0 kW, 120 ps) @ 6500 rpm <o:p></o:p>
Torque: 103 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm <o:p></o:p>
Piston Code: P29 (Equivalent to PM7) <o:p></o:p>
ECU Code: PG7 <o:p></o:p>
L3 Gearbox - Cable Tranny <o:p></o:p>
D16A3<o:p></o:p>
1986-89 Acura Integra (<st1:country-region><st1:place>Australia</st1:place></st1:country-region>) <o:p></o:p>
Power : 118 hp (88.0 kW, 120 ps) @ 5600 rpm <o:p></o:p>
Torque : 103 ft.lbf (14.3 kg/m, 140 Nm) @ 4800 rpm <o:p></o:p>
Valvetrain : DOHC, 4 valves per cylinder <o:p></o:p>
D16A6<o:p></o:p>
Also known as D16Z2.<o:p></o:p>Found in: <o:p></o:p>
1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD <o:p></o:p>
1990-1991 Honda Civic EX Sedan <o:p></o:p>
1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ) <o:p></o:p>
1989-1996 Rover 216/416 GSi/Tourer (UK/Europe) <o:p></o:p>
Rod/Stroke : 1.52 <o:p></o:p>
Power : 108 hp (80.5 kW, 110 ps) @ 5600 rpm <o:p></o:p>
Note: 1988 engines were 105 hp (78.3 kW, 107 ps) <o:p></o:p>
Torque : 100 ft·lbf (13.9 kg/m, 136 Nm) @ 4,800 rpm <o:p></o:p>
Redline : 6500 rpm (<st1:country-region><st1:place>USA</st1:place></st1:country-region>) <o:p></o:p>
Rev limited to : 7200 rpm <o:p></o:p>
ECU Code : PM6 <o:p></o:p>
D16A7<o:p></o:p>
(Basically a D16A6 that came without a catalytic converter)<o:p></o:p>Found in: <o:p></o:p>
88-89 Civic models in <st1:place>Europe</st1:place>(ED4,ED7) <o:p></o:p>
95 Civic models in New Zealand (EG4) <o:p></o:p>
88-95 Models in <st1:country-region><st1:place>South Africa</st1:place></st1:country-region> <o:p></o:p>
Ballade SH4 and SR4 ( D16A7 / EE4 ) <o:p></o:p>
Displacement : 1,579 cc (96.4 cu in) <o:p></o:p>
Power : 115 hp (85.8 kW, 117 ps) @ 5900 rpm <o:p></o:p>
Torque : 100 ft·lbf (13.9 kg/m, 136 Nm) @ 4800 rpm <o:p></o:p>
ECU: P27 (OBD-1) <o:p></o:p>
Fuel Control : OBD-0 <st1:place>ffice:smarttags" /><ST1:PlaceType>Multi-point</ST1:PlaceType> <ST1:PlaceName>PGM-FI</ST1:PlaceName></st1:place>, OBD-1 (NZDM) <o:p></o:p>
D16A8<o:p></o:p>
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia) <o:p></o:p>
1992-1995 Rover 216/416 GTi(UK/Europe) <o:p></o:p>
1993-1997 Rover 216 SportCoupe (<st1:place>Europe</st1:place>) <o:p></o:p>
Power : 125 hp (93.2 kW, 127 ps) @ 6800 rpm <o:p></o:p>
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 5900 rpm <o:p></o:p>
ECU Code : PP5 <o:p></o:p>
Gearbox : L3 <o:p></o:p>
D16A9<o:p></o:p>
(Same as D16A8 but without a catalytic converter)<o:p></o:p>Found in: <o:p></o:p>
1988-1991 Concerto (UK/Europe) <o:p></o:p>
1988-1991 CRX 1.6i-16(UK/Europe/South <st1:place>Africa</st1:place>) <o:p></o:p>
1989-1992 Rover 216/416 GTi (UK/Europe) <o:p></o:p>
1992-1995 Civic Si (Japanese and Peruvian version) <o:p></o:p>
Displacement : 1,598 cc (97 cu in) <o:p></o:p>
Compression : 9.5:1 (p29 pistons) <o:p></o:p>
Power : 137 hp (96.9 kW, 132 ps) @ 6.800 rpm <o:p></o:p>
Valvetrain : DOHC 16 valve (4 valves per cylinder) <o:p></o:p>
Redline: 7500 rpm <o:p></o:p>
Limit: 7800 rpm <o:p></o:p>
Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1) <o:p></o:p>
ECU Code: PM7 (P29 OBD1) <o:p></o:p>
GearBox : <NON LSD>(88-91 L3) (LSD 92- 95 S20) <o:p></o:p>
D16B5<o:p></o:p>
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)<o:p></o:p>Found in: <o:p></o:p>
1998-2000 Honda Civic GX <o:p></o:p>
Compression : 12.5:1 <o:p></o:p>
Combustion Chamber Volume : 32.8 cc per cylinder <o:p></o:p>
Valvetrain : SOHC VTEC-E <o:p></o:p>
VTEC Switchover : 5700 rpm <o:p></o:p>
ECU Code: PDN-A02 <o:p></o:p>
D16W7<o:p></o:p>VTEC-E <o:p></o:p>
2005-2007 Honda Civic Vti-L/ Vti (<st1:place>Asia</st1:place>) <o:p></o:p>
Displacement:1,590 cc (97 cu in) <o:p></o:p>
Compression : 10.9:1 <o:p></o:p>
Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm <o:p></o:p>
Torque : 112 ft·lbf (15.5 kg/m, 152 Nm) @ 4300 rpm <o:p></o:p>
Redline : 6100 rpm <o:p></o:p>
Limit : 6200 rpm <o:p></o:p>
ECU Code : PM12 <o:p></o:p>
Also found in 2001-2005 Honda Civic ES (<st1:place>Europe</st1:place>) <o:p></o:p>
Same as above, except: <o:p></o:p>
Power: 110 hp (82.0 kW, 81 kW) @ 5600 rpm <o:p></o:p>
Redline 6100 rpm <o:p></o:p>
Limit 6200 rpm <o:p></o:p>
D16Y1<o:p></o:p>Found in <o:p></o:p>
1992-1995 Honda Civic VTi (AUS) <o:p></o:p>
Power : 129 hp (96.2 kW, 131 ps) @ 6600 rpm <o:p></o:p>
Torque : 107 ft·lbf (14.8 kg/m, 145 Nm) @ 5200 rpm <o:p></o:p>
VTEC Switchover : 5000 rpm <o:p></o:p>
ECU Code : P28 <o:p></o:p>
D16Y4<o:p></o:p>Found in: <o:p></o:p>
1998-2000 Civic iES (<st1:country-region><st1:place>Turkey</st1:place></st1:country-region>) <o:p></o:p>
1996-2000 Civic CXi,GL,GLi (<st1:country-region><st1:place>New Zealand</st1:place></st1:country-region>,<st1:country-region><st1:place>Australia</st1:place></st1:country-region>) <o:p></o:p>
· <o:p></o:p>
Displacement : 1,590 cc <o:p></o:p>
Compression : 9.4:1 <o:p></o:p>
Power : 120 hp (88.0 kW) @ 6400 rpm <o:p></o:p>
Torque : 144 nm / 5000rpm <o:p></o:p>
Redline : 6800 rpm <o:p></o:p>
Rev-limiter: 7200 rpm <o:p></o:p>
Head Code : P2A-2 <o:p></o:p>
ECU Code : P2K <o:p></o:p>
Rod /Stroke Ratio : 1.52 <o:p></o:p>
Rod Length : 152 mm <o:p></o:p>
Deck Height : 212 <o:p></o:p>
D16Y5<o:p></o:p>VTEC-E <o:p></o:p>
1996-2000 Honda Civic HX
<o:p>[LEFT]
- 1996 Honda Civic EX(sedan Peruvian version) <o:p></o:p>
- Displacement : 1,590 cc (97 cu in) <o:p></o:p>
- Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in) <o:p></o:p>
- Rod Length : 137 mm <o:p></o:p>
- Rod/Stroke : 1.52 <o:p></o:p>
- Compression : 9.4:1 <o:p></o:p>
- Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm <o:p></o:p>
- Torque : 104 ft·lbf (14.4 kg/m, 141 Nm) @ 4500 rpm <o:p></o:p>
- Valvetrain : SOHC VTEC-E (4 valves per cylinder) <o:p></o:p>
- Fuel Control : OBD-2 MPFI <o:p></o:p>
- Head Code : P2J <o:p></o:p>
- 1996-2000 VTI <o:p></o:p>
- VTEC-E <o:p></o:p>
- FOUND IN <o:p></o:p>
- Compression : ?:? <o:p></o:p>
- Power : 127 hp (94.7 kW, 129 ps) @ 5800 rpm <o:p></o:p>
- Torque :111 ft·lbf (? kg/m, ? Nm) @ ? rpm <o:p></o:p>
- Valvetrain : SOHC VTEC(4 valves per cylinder) <o:p></o:p>
- ECU Code : p2n <o:p></o:p>
- Piston Code : P2MY <o:p></o:p>
[/LEFT]
D16Y7<o:p></o:p>
- 1996-2000 Honda Civic DX/VP/LX/CX <o:p></o:p>
- 1999-2000 Honda Civic Special Edition - SE(<st1:country-region><st1:place>Canada</st1:place></st1:country-region>) <o:p></o:p>
- 1996-97 Honda <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:State><st1:place>del</st1:place></st1:State> Sol S <o:p></o:p>
- 1997 Honda Civic Coupe LSI <o:p></o:p>
- Displacement : 1,593 cc (97.2 cu in) <o:p></o:p>
- Power : 106 hp (79.0 kW, 107 ps) @ 6400 rpm <o:p></o:p>
- Torque : 103 ft·lbf (140 N<SUP>.</SUP>m) @ 4,600 rpm <o:p></o:p>
- Redline : 6800 rpm <o:p></o:p>
- Rev-limiter: 7200 rpm <o:p></o:p>
- Valvetrain : SOHC (4 valves per cylinder) <o:p></o:p>
- Fuel Control : OBD2 MPFI <o:p></o:p>
- Head Code : P2F <o:p></o:p>
- Piston Code : P2E <o:p></o:p>
- ECU Code : P2E <o:p></o:p>
D16Y8<o:p></o:p>
VTEC<o:p></o:p>
Also available in <st1:country-region><st1:place>New Zealand</st1:place></st1:country-region> under the code D16Y6<o:p></o:p>
- 1999-2000 Honda Civic SR 1.6 Vtec (<st1:country-region><st1:place>UK</st1:place></st1:country-region>) <o:p></o:p>
- 1996-1999 Honda Civic EX Sedan <o:p></o:p>
- 1996-1999 Honda Civic EX Coupe <o:p></o:p>
- 1996-2000 Honda Civic EX (US) <o:p></o:p>
- 1996-2000 Honda Civic SI (<st1:country-region><st1:place>Canada</st1:place></st1:country-region> Only) <o:p></o:p>
- 1997-2000 Acura 1.6EL (<st1:country-region><st1:place>Canada</st1:place></st1:country-region> Only) <o:p></o:p>
- 1996-1997 Honda <st1:State><st1:place>del</st1:place></st1:State> Sol Si <o:p></o:p>
- 1997-2000 Rover 416 Auto <o:p></o:p>
Displacemnt : 1590cc <o:p></o:p>
Rod Length : 137 MM <o:p></o:p>
Valvetrain : SOHC VTEC 4 valves per cylinder <o:p></o:p>
Power : 127 hp (94.7 kW, 129 ps) 6600 @ rpm <o:p></o:p>
Torque : 111 ft·lbf (145.1 N<SUP>.</SUP>m) 5500@ rpm <o:p></o:p>
Piston Code : P2P <o:p></o:p>
Redline 6900 rpm <o:p></o:p>
Rev Limited To 7200 rpm <o:p></o:p>
ECU Code : P2P <o:p></o:p>
D16Y9<o:p></o:p>
equal to D16Y4<o:p></o:p>
non vtec<o:p></o:p>
- 1996-2000 Honda Ballade, Honda Civic in <st1:country-region><st1:place>South Africa</st1:place></st1:country-region> and <st1:country-region><st1:place>Venezuela</st1:place></st1:country-region> <o:p></o:p>
- (79.0 kW, 107 ps) @ 5900 rpm (At 110 hp (82 kW) @ 5500 rpm) <o:p></o:p>
- Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 4000 rpm <o:p></o:p>
- Fuel Control : OBD2A MPFI <o:p></o:p>
- Head Code : P2A <o:p></o:p>
- Piston Code : P2K <o:p></o:p>
- ECU Code : P2K 2 Connectors <o:p></o:p>
The D16Y9 in <st1:country-region><st1:place>South Africa</st1:place></st1:country-region> has different power figures: <o:p></o:p>
- Power: 89Kw (119 hp) @6400rpm <o:p></o:p>
- Torque: 146Nm (108 lbf-ft) @5500rpm <o:p></o:p>
Information found in April 1998 CAR Magazine(SA) <o:p></o:p>
D16Z5<o:p></o:p>
(Basically the same engine as the D16A9, but now with a catalytic converter and lambda sensor)<o:p></o:p>
- 1988-1992 Honda CRX (European Market) <o:p></o:p>
- Compression : 9.5:1 <o:p></o:p>
- Power : 124 hp (92.5 kW, 126 ps) @ 6800 rpm <o:p></o:p>
- Torque : 103 ft·lbf (14.3 kg/m, 140 Nm) @ 5600 rpm <o:p></o:p>
- Valvetrain : DOHC (4 valves per cylinder) <o:p></o:p>
- <st1:place>Cam</st1:place> Gear : 34 tooth <o:p></o:p>
- Fuel Control : OBD-0 PGM-FI <o:p></o:p>
- Head Code : P7 <o:p></o:p>
- Piston Code : PM7 <o:p></o:p>
- ECU Code: PM7 <o:p></o:p>
D16Z6<o:p></o:p>
- 1992-1995 Honda Civic EX (Japan Market) <o:p></o:p>
- 1992-1995 Honda Civic EX, EX-V(US) <o:p></o:p>
- 1992-1995 Honda Civic Hatchback Si,(US) <o:p></o:p>
- 1992-1995 Honda Civic ESi (European Market) <o:p></o:p>
- 1993-1995 Honda Del Sol Si (US) <o:p></o:p>
- 1992-1995 Honda CRX del Sol ESi (European) <o:p></o:p>
- Rod Length : 137MM <o:p></o:p>
- Compression : 9.2:1 <o:p></o:p>
- Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm <o:p></o:p>
- Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm <o:p></o:p>
- Piston Code : P28 <o:p></o:p>
- Volumetric Efficiency : 87.68% <o:p></o:p>
- Redline : 7200 rpm <o:p></o:p>
- Fuel Cut : 7411 rpm <o:p></o:p>
- VTEC engagement : 4800 rpm<SUP>[2]</SUP> <o:p></o:p>
- Fuel Control : OBD-1 MPFI <o:p></o:p>
- Head Code : P08 <o:p></o:p>
- ECU Code : P28 <o:p></o:p>
D16Z9<o:p></o:p>
- 1994-1995 Civic Coupe (EJ1) 1.6i ESi European <o:p></o:p>
- 1994-1995 Civic <st1:City><st1:place>Sedan</st1:place></st1:City> (EG9) 1.6i EX US <o:p></o:p>
- Compression : 9.3:1 <o:p></o:p>
- Torque : 106 ft·lbf (14.7 kg/m, 144 Nm) @ 5200 rpm <o:p></o:p>
- Fuel Cut : 7500 rpm <o:p></o:p>
- Valvetrain : SOHC VTEC (4 valves per cylinder) <o:p></o:p>
D17 Series Engines (1.7 Liters)<o:p></o:p>
· <o:p> </o:p>
- D17A 2001-2005 (<st1:country-region><st1:place>Japan</st1:place></st1:country-region>) honda civic <o:p></o:p>
- Displacement : 1,668 cc (101.8 cu in) <o:p></o:p>
- Bore and Stroke: ? <o:p></o:p>
- Power : [lean burn] 115 hp (85.8 kW, 117 ps) @ ? rpm; 130 hp (96.9 kW, 132 ps) @ ? rpm <o:p></o:p>
- Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm <o:p></o:p>
D17A1<o:p></o:p>
- 2001-2005 Honda Civic DX/LX/VP <o:p></o:p>
- Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.72 in) <o:p></o:p>
- Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm <o:p></o:p>
- Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm <o:p></o:p>
- RPM redline: 6750 rpm <o:p></o:p>
- Rev-limiter : 7200 rpm <o:p></o:p>
D17A2<o:p></o:p>
VTEC-E <o:p></o:p>
- 2001-2005 Honda Civic EX (US only) <o:p></o:p>
- 2001-2005 Honda Civic LX (<st1:place>Europe</st1:place>) <o:p></o:p>
- 2001-2005 Honda Civic Si (<st1:country-region><st1:place>Canada</st1:place></st1:country-region> only) <o:p></o:p>
- 2001-2005 Acura 1.7 EL (<st1:country-region><st1:place>Canada</st1:place></st1:country-region> only) <o:p></o:p>
- 2000-2007 Honda Stream 1.7 (<st1:country-region><st1:place>Japan</st1:place></st1:country-region>) <o:p></o:p>
- Bore and Stroke : 74.98 mm × 94.4 mm (2.952 in × 3.72 in) <o:p></o:p>
- Rod/Stroke : 1.48 <o:p></o:p>
- Compression : 9.9:1 <o:p></o:p>
- Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm <o:p></o:p>
- Torque : 114 ft·lbf (114 ft·lbf USDM<SUP>[3]</SUP>) (15.8 kg/m, 155 Nm) @ 4800 rpm <o:p></o:p>
- RPM redline: 6800 rpm <o:p></o:p>
- VTEC Switchover : 3200 rpm <o:p></o:p>
D17A6<o:p></o:p>
VTEC-E <o:p></o:p>
- 2001-2005 Honda Civic HX <o:p></o:p>
- Power : 117 hp (93.2 kW, 127 ps) @ 6100 rpm<SUP>[4]</SUP> <o:p></o:p>
- Torque : 111 ft·lbf (15.3 kg/m, 150 Nm) @ 4500 rpm <o:p></o:p>
- Valvetrain : SOHC VTEC-E Lean Burn (4 valves per cylinder) <o:p></o:p>
- VTEC Switchover : ??? <o:p></o:p>
D17A7<o:p></o:p>
- 2001-2005 Honda Civic GX <o:p></o:p>
- Fuel CNG (Compressed Natural Gas) <o:p></o:p>
- Compression : 12.5:1 <o:p></o:p>
- Power : 100 hp (74.6 kW, 101 ps) @ 6100 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4000 rpm <o:p></o:p>
- ZC(similar to D16Y4, D16A8, D16Z6, D16A1, D16A3, D16A6, D16A9 and D16Z5 engines)<o:p></o:p>
- EB1
- 1973- Honda Civic
- EB2
- 1974-1979 Honda Civic
- EB3
- 1978-1979 Honda Civic
- ECA1
- 2000-2006 Honda Insight
- ED1
- 1975- Honda Civic CVCC
- ED2
- 1975- Honda Civic Wagon
- ED3
- 1976-1979 Honda Civic CVCC
- ED4
- 1976-1979 Honda Civic Wagon
- 1976-1978 Honda Accord
- EJ1
- 1980- Honda Civic
- 1981-1983 Honda Civic CVCC
- EK1 2-port
- 1979 Honda Accord
- 1979 Honda Prelude
- EK1 4-port
- 1980-1981 Honda Accord
- 1980-1981 Honda Prelude
- EK1 4-port (Revised)
- 1982-1983 Honda Accord
- 1982 Honda Prelude
- 1981-1985 Honda Vigor
- EL1
- 1979-1983 Honda Accord Non USDM
- 1979-1982 Honda Prelude (Australian and Canadian models) Non USDM
- EM
- EM1
- 1980 Honda Civic, 52 hp (39 kW)
- 1981-1983 Honda Civic, 63 hp (47 kW)
- ES1
- 1983-1984 Honda Prelude
- ES2
- 1984-1985 Honda Accord
- ES3
- 1985- Honda Accord SE-i
- ET1
- 1984-1985 Honda Accord (Non USDM Only)
- ET2
- 1985-1986 Honda Prelude
- EV1
- 1984-1986 Honda Civic
- 1984-1986 Honda CRX
- EV2
- 1984-1990 Rover 213 (70 hp)
- EW1
- 1984-1985 Honda Civic/CRX DX(unlabeled)
- 1984-1987 Honda Civic
- EW2
- 1984-1987 Honda Civic non-CVCC EFI (CDM) <o:p></o:p>
- EW3
- 1985- Honda Civic/CRX Si non-CVCC <o:p></o:p>
- EW4
- 1985-1987 Honda CRX Si non-CVCC
- 1986-1987 Honda Civic Si non-CVCC
- EW5
- similar to the EW1, Fuel injected CVCC 12Valve 4 Aux valves. A third throttle plate in the throttle body supplied intake air to a 5th injector which powered the CVCC ports, The rated power is different between the Civic and the CR-X the Civic makes 100 PS (99 hp) 5800 rpm 13.2 kg/m (9.7 lb·ft) torque @ 4000 rpm, the CR-X made 110 PS (110 hp) 5800 rpm 13.8 kg/m (10.2 lb·ft) torque @ 4500 rpm. Differences in power are largely down to a more efficient exhaust system on the CR-X it used a factory cast iron <st1:date Month="4" Day="2" Year="2001">4-2-1</st1:date> extractor went through a catalytic converter further down the exhaust system and had twin exit tail pipes. The Civic had a short 4-1 design into a catalytic converter and single pipe exit. There was a revised intake manifold for vehicles produced in 1986 and 1987. The EW5 was only available in <st1:country-region><st1:place>Japan</st1:place></st1:country-region>. It came in the following models: CR-X 1.5i, Civic 25i Hatchback, Ballade CRi Sedan.
- SOHC 12 valve CV carburetor
- Displacement: 547cc
- Inside diameter × stroke: 62.5 × 59.5
- Horsepower: 26 kW (36PS) / 6,500 rpm
- Torque: 44N m (4.5 kg m) / 5,200 rpm <o:p></o:p>
- (JW2 Honda Today)
- (HA1, HH1 Honda Acty)
- PGM-FI SOHC 12 Valve
- Horsepower: 32 kW (44PS) / 8,000 rpm
- Torque: 45N m (4.6 kg m) / 4,500 rpm <o:p></o:p>
- (JW2 Honda Today)
- (HA2, HH2 Honda Acty)
- Name E07A
- Form 3-cylinder water-cooled series
- Gasoline Fuel
- 656cc total emission
- 2 belt drive mechanism of the intake and exhaust valve SOHC 2
- Bore × Stroke (mm) 66.0 × 64.0
- The basic specification is as above. The fuel supply system, due to carburetor, fuel injection (Honda PGM-FI) by a sequential multi-throttle system and there is MTREC (Multi Throttle Responsive Engine Control). The highest torque output of different models.
</o:p></o:p></o:p>
E07A
· <o:p> </o:p>
- Displacement: 656cc
- Inside diameter × stroke: 66.0 × 64.0
- Horsepower: 31 kW (42PS) / 6,000 rpm
- Torque: 53N m (5.4 kg m) / 5,000 rpm <o:p></o:p>
(JA2 Honda Today)
E07A (PGM-FI version)
· <o:p> </o:p>
- Horsepower: 43 kW (48PS) / 6,300 rpm
- Torque: 57N m (5.8 kg m) / 5,500 rpm <o:p></o:p>
(JA4 Honda Today)
MTREC (E07A)
NATURALASPIRATION in order to achieve higher output in the engine intake manifold of the lower chamber of each cylinder intake capacity (INMANI) have a separate throttle valve. Controlled by engine rpm and throttle opening degree of the air-fuel ratio (θTH-Ne), and sharp throttle response. In addition, when idling is controlled by negative pressure and engine rpm INMANI (Pb-Ne: D Nick JETRO) switch, and has both a high idle stability.
E07A (MTREC version)
- SOHC 12 valve MTREC
- Horsepower: 47 kW (64PS) / 8,100 rpm
- Torque: 60N m (6.1 kg m) / 7,000 rpm <o:p></o:p>
(PP1 Honda Beat)
(JA4 Honda Today)
E07Z
The revision to the mini-vehicle standards, improve environmental performance (LEV-) goal was to improve fuel efficiency.
For improving environmental performance, improving the combustion DIRECTIGNITION the adoption of the compression ratio and optimized, high performance three-way catalyst was mounted immediately after the engine (by expanding the area of the cell-reaction) to the , improving the speed and accuracy of air-fuel ratio control.
For improved fuel efficiency, improve the combustion and reduce friction through adoption of the rocker arm type ROLLERFORWARD was supported by the low rotational torque by adopting improved knock control.
3-Mode VTEC (ECA)
Been developed for the Insight is Honda's first hybrid cars, DC to assist low-profile for mounting between a brushless motor and transmission, 995cc engine displacement of the cylinder and the three, tried a compact and lightweight.
VTEC-E, based on type and use the rocker arm ROLLERFORWARD, VTEC valve to narrow the angle due to the clip and roller pin coaxial switch, enabling rotation 3-Mode in the region to give rise to civil strong swirl did.
Other, reducing friction and is offset from the axis of the cylinder crankshaft, changes were made from lightweight materials fee.<SUP>[1]</SUP>
· <o:p> </o:p>
- ECA specifications
- SOHC 12 valve VTEC PGM-FI
- Displacement: 995cc
- Inside diameter × stroke: 72.0 × 81.5
- Horsepower: 50 kW (70PS) / 5,700 rpm
- Torque: 92N m (9.4 kg m) / 4,800 rpm (ZE1 Honda Insight coupe) <o:p></o:p>
E07Z
· <o:p> </o:p>
- Horsepower: 39 kW (53PS) / 7,000 rpm
- Torque: 61N m (6.2 kg m) / 4,000 rpm (HM2 Honda Vamos)
Honda Acty truck (HA6 / 7)
Honda Acty van (HH5 / 6)
Honda Vamos / Honda Vamos Hobio (HM1 / 2)
E07Z (turbo version)
· <o:p> </o:p>
- PGM-FI SOHC 12 valve turbo
- Horsepower: 47 kW (64PS) / 6,000 rpm
- Torque: 93N m (9.5 kg m) / 3,700 rpm (HM1 Vamos)
- Honda Vamos / Vamos Hobio (HM1 / 2)
Honda Life Dunk (JB3 / 4)
Honda Z (PA1)
Honda That's (JD1/2)
F-SERIES:
SOHC engines
F18A
This engine was used by Honda.
Bore × Stroke: 85.0 × 81.5 mm
Displacement: 1849 cc
Valve Configuration: SOHC, 16 valves
118 bhp up to 1997
105PS @ 6000 rpm, 14.6 kg m @ 4000 rpm (PGM-carb)
Fuel consumption : 13.0 km/l
F18B
This engine was used for the Honda Accord 1.8 VTS/VTE in Japan. Also found in the European Honda Accord Vtec S.
Specifications
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 138PS (103 kW)
Max torque: 124 ft·lbf (165 N m) <o:p></o:p>
F20A
This engine series was used in the Honda Accords and Prelude`s in Japan and Europe. The DOHC F20A was also derived from this engine (see below).
Specifications
Bore × Stroke: 85.0 × 88.0 mm
Displacement: 1997 cc
Compression ratio : 9.5:1
Max output : F20A2 110 Ps @ 6000 rpm (PGM-carb)
Max output : F20A4 133 Ps @ 5400 rpm (PGM-Fi)
Max output : F20A5 150 Ps @ 5400 rpm (PGM-Fi)
Max output : F20A7 135 Ps @ 5600 rpm (PGM-Fi)
Max output : F20A8 145 Ps @ 5900 rpm (PGM-Fi)
Max torque : F20A2 16.1 kg m @ 3800 rpm (PGM-carb)
Max torque : F20A4 18.5 kg m @ 4300 rpm (PGM-Fi)
Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi)
Max torque : F20A8 138ft/lb @ 4400 rpm (PGM-Fi)
Fuel consumption F20A8 Urban - 25 mpg Highway - 34 mpg
Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
This engine also spawned many variants, according to market, but the specs remain largely similar, The F20A5 it's used in the Cb3 and Cb4 Chassis
The F20A7 is only used in the european "Accord Coupé 92-93" CC1 chassis as unique motorisation.
F20B
The F20B Engine Stream produces 113 kW (154 hp) at 6500 rpm and maximum torque of 186 N•m (137 lb•ft) at 4000 rpm, versus the single-camshaft F20B's 110 kW (148 hp) and 186 N•m (137 lb•ft), respectively. The vehicle's Japanese urban 10/15-mode fuel consumption rating is 14.2 km/L (about 34 mpg)—a 15% improvement over a comparable vehicle powered by the F20B, according to Honda.
Specifications
Configuration Valve: SOHC/DOHC, 16 valves, VTEC/Non-Vtec <o:p></o:p>
This engine came in SOHC in vtec and non vtec, there is also a DOHC VTEC version of the engine, they all share the same engine code although they are very different.
The DOHC VTEC version comes with a blue powder coated valve cover as the H23A VTEC from the japanese accord sir-t. They're called BLUE TOP and are only from japan.
DOHC VTEC Manual Version:
197 HP @ 7200RPM
145 TQ @ 6600RPM
147.10 kw
11.0:1 CR
85mm bore
88mm stroke
23mm wrist pin
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains like h22a4 block
rod journal has been offset ground on both sides to the size of a b-series rod journal.
F20Z
This engine series is similar to the F20A above, used in the Honda Accord in Asia and Europe.
Specifications
F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
Specifications
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Valve Configuration: SOHC, 16 valves, non-VTEC <o:p></o:p>
Compression ratio: 8.8:1
Max power:
F22A1: 125 hp (93.21 4 kW) @ 5200 rpm. NOTE* The 1992-1996 Prelude S had a F22A1 but because of a different more aggressively tuned ECU (P12), the power output was 135 hp (101 kW).
F22A4: 130 hp (96.94 kW) @ 5200 rpm. The F22A4 is the same motor as the F22A1 but it has slightly more power due to a tubular designed header and slightly bigger exhaust piping.
F22A6: 140 hp (104.40 kW) @ 5600 rpm. The F22A6 is the same as the F22A1 except for a slightly more aggressive camshaft, a better flowing cast exhaust manifold, a different more aggressively tuned ECU (PT6), and a different intake manifold that utilizes IAB's and also has a bigger plenum. The F22A6 also has a windage tray in the oil pan, and stiffer valve springs to accommodate the more aggressive camshaft.
F22A7: 140 hp (104.40 kW) @ 5900 rpm (147 hp/108 kW with manual transmission)
Max torque:
F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
F22A7: 145 ft·lbf (198 N m) @ 5000 rpm
F22B1
This engine was used in the Honda Accord EX and Acura CL 2.2. It was the first F engine to feature VTEC. This engine has a different head than the F22A6 (specifically exhaust manifold/header-pipe as well as intake gasket).
Specifications
Max power: 145 hp (108 kW) @ 5500 rpm
Max torque: 147 ft·lbf (199 N m) @ 4500 rpm <o:p></o:p>
F22B2
This engine was used in the 1994-1997 Honda Accord DX, LX and SE. The F22B6 in the 1995-1997 Honda Odyssey and the F22B8 in the Honda Shuttle are substantially similar. Also the F22B3 engine used in the 1994-1997 Australian and <st1:country-region><st1:place>New Zealand</st1:place></st1:country-region> Honda Accord LXi are basically the same engine apart from slightly different intake and exhaust manifolds.
Specifications
Max power: 130 hp (97 kW) @ 5300 rpm
Max torque: 139 ft·lbf (188 N m) @ 4200 rpm <o:p></o:p>
The F22B in the BA9 Prelude had a DOHC configuration
JDM engines were stamped only as F22B.
F22Z2
This engine was used in the Honda Accord 2.2i.
Specifications
Max power: 150 hp (112 kW) @ 5500 rpm
Max torque: 148 ft·lbf (200 Nm) @ 4500 rpm <o:p></o:p>
F23A===F23A1
This engine was used in the 1998-2002 Honda Accord LX, EX, and SE, and in the Acura 2.3CL in North America.
Specifications
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 ft·lbf (205 N m) @ 4900 rpm <o:p></o:p>
F23A4
This engine was used in the 1998-2002 Honda Accord ULEV models. It is substantially similar to the F23A1, but features ULEV certification with a slight reduction of power: 148 hp (108 kW) with a maximum torque of 150 ft·lbf (203 Nm). This engine has a different exhaust manifold and a 32-bit ECU which uses a wideband oxygen sensor.
F23A5
This engine was used in the 1998-2002 Honda Accord DX and the 2002 Honda Accord LX VP (value package) in North America.
Specifications
Max power: 135 hp (100 kW) @ 5500 rpm
Max torque: 153 ft·lbf (206 Nm) @ 4500 rpm <o:p></o:p>
F23A7
This engine was substantially similar to the F23A1. It was used in the 1998 Honda Odyssey and the 1998-1999 Isuzu Oasis.
DOHC engines
F20A
This engine was used in the 1990–1993 CB3 and CB4 Honda Accord 2.0Si and Si-T in Japan.
Specifications
Valve Configuration: DOHC, 16 valves
Compression ratio: 9.5:1
Max power: 150 hp (112 kW) @ 6100 rpm
Max torque: 137 ft·lbf (186 Nm) @ 5000 rpm <o:p></o:p>
F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from <st1:country-region><st1:place>Japan</st1:place></st1:country-region>. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart.
Specifications
Accord SiR wagon, SiR-T F20B 97-01 2.0L
Valve train: 4 Cylinder, DOHC VTEC, 16 Valve
Bore: 85.0 mm
Stroke: 88.0 mm
Torque: 145 ft·lbf (197 N·m) @ 5500 rpm <o:p></o:p>
Horsepower: 200 hp (150 kW) @ 7000 rpm
Red Line: 7600 rpm
Compression: 11.0:1
Fuel Control: OBD-2
F20C
Main article: Honda F20C engine
This engine was a radical departure from previous F engines, and only shared basic dimensions such as bore spacing. It was designed specifically for the Honda S2000 and shares some engineering with the Honda K engine. A long-stroke F22C1 variant was also produced.
F22B
This engine was used in the 1992–1996 Honda Prelude Si in Japan. It is similar to the H23A.
Specifications
2.2 L
Max power: 166 hp (119 kW) @ 6000 rpm
Max torque: 150 ft·lbf (200 N m) @ 5000 rpm <o:p></o:p>
F20C
Displacement: 1,997 cc (121.9 cu in)
Compression: 11.7:1
Bore: 87 mm
Stroke: 84 mm
Rod Length: 153 mm
Rod/stroke ratio: 1.82
Power: 250 PS (183.88 kW) @ 8,300rpm & 22.2kgm (217.71 Nm) @ 7,500 rpm
Redline: 9000 rpm
VTEC: 6100 rpm
</o:p></o:p>The F20C was designed with high maximum rpm capability in mind, for increased power output; redline is at 9000 rpm, with VTEC engagement at 6000 rpm. F20C relatively long stroke of 84mm and 9000 rpm result in a mean piston speed of 4965 ft/m or 25m/s, which is the highest piston speed for any production car to date.[1] Power output is 240 bhp (179 kW) at 8300 rpm in North America and Europe. The Japanese version, which has a higher compression ratio, is capable of 250 PS (247 bhp) at 8600 rpm. Honda's F20C Engine won a spot on Wards' 10 Best Engines List four times, in 2000, 2001, 2002 and 2003.
The engine displaces 1,997 cc (121.9 cu in), lending to the Honda S2000's name. This method of naming follows suit with the rest of the Honda S roadsters (i.e. Honda S500, S600, and S800).
The F20C's bore is 87 mm (3.4 in) and stroke is 84 mm (3.3 in).
Applications:
• 1999-2004 Honda S2000 (Japan)
• 2000-2003 Honda S2000 (F20C1) (North America)
• 1999–present Honda S2000 (United Kingdom, Europe, Australia)
The F20C produces the highest specific power output for any naturally aspirated 2.0L piston engine in a car worth less than US$100,000, at 123.5 hp (92.1 kW) per liter, ahead of the 1.6 L (98 cu in) Honda B16B engine found in the 1996-2000 Honda Civic Type R producing 185 bhp (138 kW) for a specific power of 115.8 bhp (86.4 kW) per liter. In fact, the F20C held the record for producing the highest specific output for any production naturally aspirated engine until Ferrari released the 458 Italia in 2010. The Italia produces 124.5 HP/L, besting the F20C only by 1 HP/L. This is a great achievement in automotive engineering, considering the F20C was released 11 years earlier and in a lower priced car.
F22C
F22C
In 2004, Honda produced a stroked 90.7 mm (3.57 in) version of the F20C, increasing displacement by 160 cc (9.8 cu in) to 2,157 cc (131.6 cu in). Dubbed the F22C1, it was originally designed for the North American market being introduced for the 2004 model year. Rated torque increased from 153 ft•lbf (207 N•m) at 7500 rpm for the F20C to 162 ft•lbf (220 N•m) at 6200 rpm for the F22C. The redline was reduced from 9000 rpm to 8000 rpm, mandated by the longer travel distance of the pistons. Peak horsepower output is rated identical to the F20C.
The F22C1 was used exclusively in the North American market for 2004 and 2005 with the F20C being used in all other markets. Despite the displacement increase, the car to which the F22C1 is mated retains the name of Honda S2000. In 2006, the engine fully replaced F20 engines in the Japanese market as well which resulted in a drop in rated power output from 250 PS (247 bhp) to 242 PS (239 bhp) due to compression being reduced from 11.7:1 to 11.0:1. The UK, European, and Australian markets are currently the only areas in which the S2000 retains the F20C.
Applications:
• 2004–present Honda S2000 (F22C1)(North America)
• 2005–present Honda S2000 (Japan)
G-SERIES :
The Honda G series engine is an inline 5 cylinder gasoline engine, originally used in the 1992 Acura Vigor, Honda Rafaga, Honda Ascot and Honda Inspire. It carried over to the Vigor's successor the 2.5TL, which ran from 1995-1998.
Some people mistakenly refer to an F-series block (found on Accords) with an H-Series head (found on Preludes) as a G-series engine. This combination of an Accord bottom end with a Prelude head has nothing in common with the actual G-series engine.
Specifications
• Type: In-line 5 cylinder, aluminum block and head
• Valve Configuration: SOHC, with 4 valves per cylinder
G20A1
• Displacement: 1,990 cc (121 cu in)
G25A1
• Displacement: 2,451 cc (149.6 cu in)
• Bore: 85.0 mm (3.35 in)
• Stroke: 86.40 mm (3.402 in)
• Compression ratio: 9.0:1
• Max Power: 176 hp (131 kW) @ 6300 rpm
• Max Torque: 170 ft•lbf (230 N•m) @3900
• Redline: 6800 rpm
• Fuel Cutoff: 7100 rpm
H-SERIES :
DOHC engines
H22
The H22 debuted in the U.S. in 1993 as the H22A1 for use in the Honda Prelude VTEC. Since then, versions of the H22 would become the Prelude's signature high-performance engine worldwide until the end of Prelude production in 2001. Variations were also used in a few Accords in Japan and Europe.
Specifications"
• Bore × Stroke: 87.0 mm × 90.70 mm (3.43 in × 3.571 in)[1]
• Displacement: 2,157 cc (131.6 cu in)[2]
• Valve Configuration: DOHC, 16 valves, VTEC[3]
• Type: In-line 4 cylinder, aluminum block and head [4]
• Compression ratio: 10.0-10.6:1 (North America)[5]; 10.0-11.0:1 (Europe); 10.6-11.0:1 (Japan)
• Max power: 185-220 hp
• Redline: 7200/7600 rpm
• Rev Cut: 7400/7800 rpm
• Engine Control System: Honda Systems PGM-FI with port fuel injection
• Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift [6]
• 92-96 versions use closed-deck blocks with FRM liners while the 97-01 versions used open-deck blocks with FRM liners.
H22A
• Found in the Japanese 4th gen Prelude Si VTEC (2WS BB4 & 4WS BB1). It produces 200 PS (147 kW; 197 hp) @ 6,800 rpm & 161.50 ft•lbf (218.96 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Japanese 5th gen Prelude SiR (2WS BB6 & 4WS BB8). It produces 200 PS (147 kW; 197 hp) @ 6,800 rpm & 161 ft•lbf (218 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Japanese 5th gen Prelude SiR S-Spec and Type-S (BB6). It produces 220 PS (162 kW; 217 hp) @ 7,200 rpm & 163 ft•lbf (221 N•m) @ 6,500 rpm and comes with a "red top".
• Found in the Japanese 6th gen Accord/Torneo Euro-R (CL1). It produces 220 PS (162 kW; 217 hp) @ 7,200 rpm & 163 ft•lbf (221 N•m) @ 6,500 rpm and comes with a "red top".
• Found in the Japanese 5th gen Accord SiR Sedan (CD6). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft•lbf (206 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Japanese 5th gen Accord SiR Coupe (CD7). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft•lbf (206 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Japanese 5th gen Accord SiR Wagon (CF2). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft•lbf (206 N•m) @ 5,500 rpm and comes with a "black top".
H22A1
• Found in the American 4th gen Prelude VTEC (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft•lbf (214 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Canadian 4th gen Prelude SR-V (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft•lbf (214 N•m) @ 5,500 rpm and comes with a "black top".
• Found in the Australian 4th gen VTi-R (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft•lbf (214 N•m) @ 5,500 rpm and comes with a "black top".
H22A2
• Found in the European 4th gen Prelude 2.2i VTEC (BB1). It produces 185 PS (136 kW; 182 hp) and comes with a "black top".
H22A3
• Found in the 1996 VTEC model (BB1) in various countries around the world denoted with regional code KU. It comes with a "black top".
H22A4
• Found in the American 5th gen Prelude Base and Type-SH (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft•lbf (212 N•m) @ 5,250 rpm and comes with a "black top".
• Found in the Canadian 5th gen Prelude Base, Type-SH, and SE (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft•lbf (212 N•m) @ 5,250 rpm and comes with a "black top".
• Found in the Australian 1997-1998 Prelude VTi-R and VTi-R ATTS (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft•lbf (212 N•m) @ 5,250 rpm and comes with a "black top".
H22A5
• Found in the European 1997-1998 Prelude 2.2VTi/VTi-S (2WS BB6 & 4WS BB8). It produces 185 PS (136 kW; 182 hp) and comes with a "black top".
H22A7
• Found in the European 1998-2002 Accord Type-R (CH1). It produces 215 PS (158 kW; 212 hp) and comes with a "red top".
H22A8
• Found in the European 1999-2001 Prelude 2.2VTi/VTi-S (2WS BB6 & 4WS BB8). It produces 200 PS (147 kW; 197 hp) and comes with a "red top".
H22Z1
• Found in the Australian 1999-2001 VTi-R and VTi-R ATTS (BB6). It is thought to be identical to the H22A4, however, there is speculation that power was increased from 200 PS (147 kW; 197 hp) to 203 PS (149 kW; 200 hp). It comes with a "black top".
Notes
1. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
2. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
3. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
4. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
5. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
6. ^ Honda Motor Co., LTD.: "1993 Prelude Service Manual", p. 3-15. Service Publication Office, 1992
H23
The H23 was an increased-stroke, non-VTEC version of the H22, used in Japan, North America, and Europe. It shared the same Fiber Reinforced Metal (FRM) cylinder wall liners with the H22.
Specifications
• Bore × Stroke: 87.0 mm × 95.0 mm (3.43 in × 3.74 in)
• Displacement: 2,258 cc (137.8 cu in)
• Compression ratio: 9.8:1
• Max power: 170 hp (127 kW; 170 hp)
• Max torque: 156 ft•lbf (212 N•m)
• Redline: 6500 rpm
• Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
H23A
• Found in the Japanese 1992-1996 Ascot Innova 2.3Si-Z (2WS CC4 & 4WS CC5). It produces 165 PS (121 kW; 163 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
H23A1
• Found in the American 4th gen Prelude Si (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
• Found in the American 1995 Prelude SE (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
• Found in the Canadian 4th gen Prelude SR (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
• Found in the Australian 4th gen Prelude Si (BB2). It produces 160 PS (118 kW; 158 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
• Found in the Australian 1991-1993 Prelude SRS (BB2). It produces 160 PS (118 kW; 158 hp) & 156 ft•lbf (212 N•m) and comes with a "black top".
H23A2
• Found in the European 4th gen Prelude 2.3i (BB2). It produces 160 PS (118 kW; 158 hp) & 154 ft•lbf (209 N•m) and comes with a "black top".
H23A3
• Found in the European 1993-1995 Accord 2.3i SR (CC7). It produces 158 PS (116 kW; 156 hp) & 154 ft•lbf (209 N•m) and comes with a "black top".
• Found in the European 1992-1996 Rover 623 SLi, GSi, and iS. It produces 158 PS (116 kW; 156 hp) & Template:Convert/ and comes with a "black top".
In 1998 Honda produced a rare VTEC version of the H23 engine for use in Japan only. It is essentially an H23 block with an H22 head. The power is on par with a typical H22 engine but with a lower redline.
Specifications
• Bore × Stroke: {{
• 1998-2002 Accord Wagon AWD (CL2). It produces 200 PS (147 kW; 197 hp) & 163 ft•lbf (221 N•m) and comes with a "blue top".
J-SERIES :
J25
The J25A was the first J-series engine produced. It was only used in the export-model Inspire/Saber models, however. The J25A displaced 2.5 L (~153 cu in) and was a SOHC Gasoline direct injection VTEC design. Output was 192 hp (143 kW).
• J25A
o 1998-2003 Honda Inspire
o 1999 Honda Saber
J30
The J30 displaces 2,997 cc (2.997 L; 182.9 cu in) and is a SOHC VTEC design. Output for the light weight 250 lb (110 kg) J30A1 was 200 hp (150 kW) and 195 lb•ft (264 N•m) of torque. The J30A4 pushed output to 240 hp (180 kW) and 212 lb•ft (287 N•m) using a three-way VTEC system, higher (10:1) compression ratio, and a novel exhaust manifold cast as one piece with the cylinder head. It weighs nearly 20 lb (9.1 kg) less and is an inch shorter than J30A1. This version was on the Ward's 10 Best Engines list for 2003 and 2004. The IMA hybrid version was on the list for 2005. In 2006 to mark the 30th anniversary of the Accord, Honda created the J30A5, which boosted output to 244 hp (SAE Net 08/04) and 211 ft•lbf (SAE Net 08/04) of torque. According to Honda, horsepower gains were achieved with extensive improvements to the airflow of the intake and exhaust system.
• J30A1
o 1997-1999 Acura 3.0CL
o 1999-2003 Honda Avancier
o 1998-2002 Honda Accord V6
• J30A4
o 2003-2005 Honda Accord V6
• J30A5
o 2006-2007 Honda Accord V6
• Variable Cylinder Management
o 2005 Honda Accord Hybrid
o 2003-2007 Honda Inspire
J32
The J32 displaces 3.2 L (~195 cu in) and is a SOHC VTEC design. Bore is 89 mm (3.5 in) and stroke is 86 mm (3.4 in). Output was 225 hp (168 kW) for the J32A1, with the J32A2 raising output to 260 hp (194 kW) @ 6200 rpm and 232 lb•ft (315 N•m) @ 3500-5500 rpm. A more aggressive camshaft, freer flowing intake/exhaust, and a 2-stage intake manifold all result in a 35 hp (26 kW) increase over the J32A1. The J32A3's output in the 2004/2005 TL is 270 hp (201 kW). SAE corrected hp for the 2006-2008 TL is 258 hp (192 kW). The J32A3 also includes the one-piece exhaust manifold cast with the cylinder head, first introduced on the J30A4.
• J32A1
o 1999-2003 Acura TL
o 2001-2003 Acura CL
• J32A2
o 2001-2003 Acura CL Type-S
o 2002-2003 Acura TL Type-S
• J32A3
o 2004-2008 Acura TL
J35
J35Z2
The J35 displaced 3,471 cc (3.471 L; 211.8 cu in) and is an SOHC VTEC design. Bore is 89 mm (3.5 in) and stroke is 93 mm (3.7 in). Output was 210 hp (157 kW) for the J35A1; 240 hp (179 kW) and 253 ft•lbf (343 N•m) (5800/4400 rpm) for the J35A3; 240 hp (179 kW) and 242 ft•lbf (328 N•m) (5500/4500 rpm) for the J35A4.
The J35A5 used in the 2004 - 2006 Acura MDX produces 265 hp (198 kW) at 5800 rpm and 250 ft•lbf (339 N•m) at 3500 rpm. The 2003 version of this engine produces 260 hp (194 kW) at 5750 rpm.
The new J35 used in the Acura RL produces 290 hp (220 kW) at 6200 rpm and 256 lb•ft (347 N•m) at 5000 rpm. This engine was on the Ward's 10 Best Engines list for 2005, 2008 and 2009.
The J35A9 used in the 2006 - 2008 Honda Ridgeline produces 247 hp (184 kW) at 5750 rpm and 245 lb•ft (332 N•m) at 4500 rpm.
The J35A3 was also used by General Motors in the 2004-2007 Saturn Vue, though it utilized the cast-iron crankshaft from the J35A4 rather than the forged-steel version of the J35A3. GM refers to it as the L66.
• J35A1
o 1999 - 2001 Honda Odyssey
• J35A3
o 2001 - 2002 Acura MDX
o 2005 - 2008 Acura RL
o 2004 - 2007 Saturn Vue L66
• J35A4
o 2002 - 2004 Honda Odyssey
o 2003 - 2004 Honda Pilot
• J35A6
o 2005 - 2009 Honda Odyssey Van, LX, EX
o 2005 Honda Pilot
• J35A7 - Variable Cylinder Management Piston Oil Jets
o 2005-2009 Honda Odyssey EX-L, Touring
o 2007-present Honda Inspire
• J35A8
o 2007 - 2008 Acura TL Type-S
• J35A9
o 2006 - 2008 Honda Ridgeline
o 2006 - 2008 Honda Pilot (VTM-4-equipped models)
• J35Z1 - Variable Cylinder Management
o 2006 - 2008 Honda Pilot (front-wheel drive models)
• J35Z2 - Variable Cylinder Management
o 2008+ Honda Accord (except V6 6MT coupe)
• Displacement: 3,471 cc (211.8 cu in)
• Bore and stroke: 89.0 mm (3.5 in) x 93.0 mm (3.7 in)
• Compression: 10.5:1
• Power, torque: 271 hp (202 kW) @ 6200 rpm; 254 ft•lbf (344 N•m) @ 5000 rpm
• Valvetrain: 24v SOHC i-VTEC
• Fuel control: Multi-point fuel injection; PGM-FI
• J35Z3
o 2008+ Honda Accord V6 6MT coupe
• Compression: 10.0:1
• Power, torque: 271 hp (202 kW) @ 6200 rpm; 251 ft•lbf (340 N•m) @ 5000 rpm
• Valvetrain: 24v SOHC VTEC
• J35Z4 - Variable Cylinder Management
o 2009 Honda Pilot
• Power, torque: 250 hp (190 kW) @ 5700 rpm; 253 ft•lbf (343 N•m) @ 4800 rpm
• Valvetrain: 24 SOHC i-VTEC
• J35Z5
o 2009 Honda Ridgeline
• Power, torque: 250 hp (190 kW) @ 5700 rpm; 247 ft•lbf (335 N•m) @ 4300 rpm
• Fuel control: Multi-point fuel inection; PGM-FI
J37
• J37A1
o 2007-2009 Acura MDX
• Displacement: 3,664 cc (223.6 cu in)
• Bore and stroke: 90.0 mm (3.5 in) x 96.0 mm (3.8 in)
• Compression: 11.0:1
• Power; torque: 300 hp (220 kW) @ 6000 rpm; 275 ft•lbf (373 N•m) @ 5000 rpm
• J37A2
o 2009 Acura RL
• Compression: 11.2:1
• Power; torque: 300 hp (220 kW) @ 6300 rpm; 271 ft•lbf (367 N•m) @ 5000 rpm
• Valvetrain: 24v SOHC VTEC (intake and exhaust)
• J37A4
o 2009 Acura TL SH-AWD
• Power; torque: 305 hp (227 kW) @ 6300 rpm; 273 ft•lbf (370 N•m) @ 5000 rpm
K Series
K20
K20A
The 1,998 cc (1.998 L; 121.9 cu in) K20 engines have 86 mm (3.4 in) bore and 86 mm (3.4 in) stroke. The 2,157 cc (2.157 L; 131.6 cu in) version has 87.0 mm (3.43 in) bore & 90.7 mm (3.57 in) stroke.
K20A2
• Found in:
o 2002-2004 RSX Type-S and 2002-2005 Honda Civic Type R (EP3, European)
Displacement: 1,998 cc (121.9 cu in)
Compression: 11.0:1
Power: 200hp @ 7400 rpm
Torque: 142 ft•lbf (196N•m) @ 5600 rpm
Redline: 7900 rpm
Rev limit: 8100 rpm (USDM RSX-S, U.K Civic-R )
i-VTEC engagement: 5800 rpm
K20A3
• Found In
o 2002-2005 Honda Civic Si (EP3)7100 rpm only apply to k20a3 ep3 base rsx 6800
o 2002-2005 Honda Civic SiR (EP3)(Canadian version of US Civic Si)
o 2002-2006 Acura RSX
Compression: 9.8:1
Power: 160hp(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 141 lb•ft (191 N•m)* (191 N•m) @ 4000 rpm(SAE net J1349 Rev 8/04)
Redline: 7100 rpm
i-VTEC Engagement Window: 2200 rpm
VTEC Engagement: 5500 rpm
K20A4
• Found in:
o 2003-2005 Honda Accord (UC1)
o 2006-2008 Honda Accord (UC3)
o 2001-2007 Honda CR-V (RD5)
o 2000-2003 Honda Stream (RN1)
o 2004-2007 Honda Stream (RN3)
K20A6
• Found in:
o 2003-2005 Honda Accord (European)
Compression 9.8:1
Bore / Stroke 86 mm x 86 mm
190nm Torque @ 4500rpm
160hp @ 6000rpm
Similar to the K20A3.
K20Z1
• Found in:
o 2005-06 Acura RSX Type-S
• Displacement: 1,998 cc (121.9 cu in)
o
Compression: 11:0:1
Power: 210 hp (154 kW) @ 7800 rpm
Torque: 143 ft•lb (194 Nm) @ 7000 rpm
Redline: 8300 rpm
i-VTEC Engagement Window:5800 rpm
K20Z2
• Found in:
o 2006- Acura CSX (Canada)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft•lbf (188 N•m) @ 4500 rpm
Redline: 6800 rpm
o 2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
o 2006- Honda Accord(Europe)
Displacement: 1998 cc
Compression: 9.6:1
Redline: 6800 rpm
K20Z3
This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S, as well as the Honda Accord CL-9 Euro R model. It has an aluminum block with an aluminum head, and a bore and stroke of 86 mm x 86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.
• Found in:
o 2006-2010 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Compression : 11:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 ft•lbf (189 N•m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
Fuel Cutoff: 8300 rpm
K20Z4
This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Type-R (FN2). It has an aluminium block with an aluminium head, and a bore and stroke of 86 mm x 86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.
• Found in:
o 2007 Honda Civic Type-R (FN2) (Europe Market)
Compression : 11.0:1
Power: 201 hp (148 kW) @ 7800 rpm
Torque: 142 ft•lbf (193 N•m) @ 5600 rpm
Redline: 8200 rpm
i-VTEC Engagement: 5,400 rpm
K23
K23A1
• Turbocharged
• Found in:
o 2007-2010 Acura RDX[1]
Displacement: 2,300 cc (140.4 cu in)
Compression: 8.8:1
Power: 240 hp (179 kW) @ 6000 rpm (SAE net)
Torque: 260 lb•ft (353 N•m) @ 4500 rpm (SAE net)
Redline: 6800 rpm
Bore: 86 mm
Stroke: 99 mm
K24
K24A4
K24A1
• Found in:
o 2002-2006 Honda CR-V
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 ft•lbf (220 N•m) @ 5200 rpm
Redline: 6500 rpm
K24A2
• Found in:
o 2004-2008 Acura TSX, JDM CL9 Accord Type-S, RB1 Odyssey Absolute
Power: 200 PS (150 kW; 200 hp) @ 6800 rpm
Torque: 232 N•m (171 lb•ft) @ 4500 rpm
Bore: 87 mm
Stroke: 99 mm
Redline:
Automatic 7100 rpm
Sequential Sportshift 7300 rpm (7100 rpm U.S.)
Manual 7600 rpm (7100 rpm U.S.)
Note: The 2006-2008 K24A2 in the U.S. market Acura TSX has the following improvements
Increased intake flow:
Intake valve + 1 mm oversize
Intake cam High lift lobe with 0.9 mm more lift and 12 degrees more duration
Throttle body increased from 60-64mm
Radius on some intake pipes increased from 70-80mm
Increased exhaust flow
Exhaust Head pipe increased frm 60-65mm
Higher flow catalytic converter
Main (single) exhaust pipe increased from 54-57mm
Rear (twin) pipes increased in diameter from 42.5 to 45mm
Block improvements:
Additional air passages in crankcase for reduced pumping losses
Other
Stronger conrods
New crankshaft with more counterbalance weight
Revised pistons with more valve-piston clearance
K24A3
• Found in:
o 2003-2007 Honda Accord (Europe(EDM)) and Japan(JDM)) and 2003-2007 Honda Accord Euro CL9 (Australia)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft•lbf (223 N•m) @ 4500 rpm
VTEC Engagement: 6000 rpm
Redline: 7400 rpm
K24A4
• Found in:
o 2003-2005 Honda Accord, 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
Torque: 161 ft•lbf (218 N•m) @ 4500 rpm (@4000 rpmin 2007/2008)
Redline: 6800 rpm
K24A8
• Found in:
Compression: 9.7:1
Power: 166 hp (124 kW) @ 6000 rpm
Torque: 160 lb•ft (217 N•m) @ 4000 rpm
Redline: 6500 rpm
o 2007-2008 Honda Element
Compression: 9.7:1
Power: 166 hp @ 5800 rpm
Torque: 161 lb•ft (218 N•m) @ 4000 rpm
Redline: 6800 rpm
K24Z1
• Found in:
o 2007- Honda CR-V (RE3, RE4)
Compression: 9.7:1
Torque: 161 ft•lbf @ 4200 rpm
Redline: 6500 rpm
K24Z2
• Found in:
o 2008 Honda Accord LX/LX-P trim models
Compression: 10.5:1
Power: 177 @ 6500 rpm
Torque: 161 ft•lbf @ 4300 rpm
Redline: 6800 rpm
K24Z3
• Found in:
o 2008 Honda Accord LX-S/EX/EX-L trim models
Compression: 10.5:1
Power: 190 @ 7000 rpm
Torque: 162 ft•lbf @ 4400 rpm
Redline: 7100 rpm
• Found in:
o 2009 Acura TSX
Compression: 11.0:1
Power: 201 @ 7000 rpm
Torque: 172 ft•lbf (MT), 170 ft•lbf (AT) @ 4300 rpm
Redline: 7100 rpm
K24Z5
• Found in:
o 2009+ Honda Spirior ; 2010+ Honda Civic
Compression: 10.5:1
Power: 184 @ 6500 rpm (133kw @ 6500 rpm)
Torque: 164 ft•lbf @ 4300 rpm (225Nm @ 4300 rpm)
Redline: 6800 rpm
K24Z6
• Found in:
o 2010 Honda CR-V (all trim models)
Compression: 10.5:1
Power: 180 HP @ 6800 RPM
Torque: 161 lbs•ft @ 4400 RPM
L-SERIES :
L-series
L12A i-DSI
Stock L12A i-DSI engine
• Available exclusively in the European domestic market Jazz (known as Fit in certain markets) and available with only a 5-speed manual transmission.
o Displacement: 1,246 cc (76.0 cu in)
o Bore x Stroke: 73.0 mm × 74.4 mm (2.87 in × 2.93 in)
o Compression Ratio: 10.8:1
o Horsepower: 57 kW (78 hp) @ 5700 rpm
o Torque: 110 N•m (81 lbf•ft) @ 2800 rpm
o Variations: L12A1
L12A i-VTEC
o SOHC 16 valve i-VTEC
o Displacement: 1,198 cc
o Inside diameter × stroke: 73.0 × 71.58
o Horsepower: 66 kW (90PS) / 6,200 rpm
o Torque: 114N m (11.2 kg m) / 4,900 rpm
o CO2 emission: 125g/km
• Honda Jazz (Germany / India)
L13A i-DSI
L13A i-DSI
• Sold as a 1.3 in the Japanese Fit and only available with the standard CVT. European version marketed as a 1.4 for the Jazz and City, and available with either 5-speed manual or CVT with 7-speed mode. Use in Australia Jazz GLi (base model) with 5-speed manual or stardand CVT. Available in other markets as well. European Civic 1.4 i-DSI has a standard 6-speed manual with an available 6-speed automated manual I-SHIFT transmission.
• For 7gen Civic, City, Fit & Jazz
o Displacement: 1,339 cc (81.7 cu in)
o Bore x Stroke: 73.0 mm × 80.0 mm (2.87 in × 3.15 in)
o Horsepower: 63 kW (84 ps) @ 5700 rpm
o Torque: 119 N•m (88 lbf•ft) @ 2800 rpm
o Variations: L13A1 (Fit/Jazz), L13A7 (European market Civic), L13A8 (European market City)
• For 8gen Civic
o Horsepower: 70 kW (95 ps)
o Torque: 130 N•m (91 lbf•ft)
o CO2 emission: 109g/km (for the Honda Civic Hybrid)
L13A i-VTEC
• Available in the Honda Fit (Japan series GE6 / GE7) and Honda Airwave in Japan.
o Inside diameter × stroke: 73.0 × 80.0
o Horsepower: 73 kW (100PS) / 6,000 rpm
o Torque: 127N m (13.kg m) / 4,800 rpm
L15A i-DSI
• Available in the Fit Aria, Mobilio, and Partner in Japan. Offered in the Fit/Jazz and City in certain countries.
o Displacement: 1,496 cc (91.3 cu in)
o Bore x Stroke: 73.0 mm × 89.4 mm (2.87 in × 3.52 in)
o Compression Ratio: 10.8:1(10.5:1 Thailand spec.)
o Horsepower: 66 kW (89 ps) @ 5500 rpm (88 ps Thailand spec, 77 ps India spec.)
o Torque: 131 N•m (97 lbf•ft) @ 2700 rpm
o Unleaded 91 octane fuel(Thailand spec.)
L15A VTEC
Stock L15A1-VTEC engine
• Available in the Fit, Fit Aria, Airwave, Mobilio, and Mobilio Spike in Japan. Sold throughout the world with 5-speed manual or CVT options in the Fit/Jazz and City. Canadian and US Fit models will have a 5-speed automatic instead of the CVT.
o Compression Ratio: 10.4:1
o Horsepower: 81 kW (109 ps) @ 5800 rpm
o Torque: 143 N•m (105 lbf•ft) @ 4800 rpm
o Variations: L15A1 (Fit/Jazz)
L15A (i-VTEC)
o Inside diameter × stroke: 73.0 × 89.4
o Compression: 10.2 : 1
o Horsepower: 88 kW (120PS) / 6,600 rpm
o Torque145N m (14.8 kg m) / 4,800 rpm (GE8 fit)
• Honda Fit (Japan series GE8 / 9)
• Honda Freed (Japan series GB3 / 4)
• Honda Aria (Japan series GM2)
LDA (i-DSI + pause-cylinder i-VTEC)
o SOHC 8 valve cylinder i-DSI + pause i-VTEC
o Horsepower: 65 kW (88PS) / 5,800 rpm
o Torque 121N m (12.3 kg m) / 4,500 rpm
• Honda Insight (ZE2) sedan
LDA (i-DSI +3 stage i-VTEC)
o SOHC 8 valve i-DSI +3 stage i-VTEC
o Horsepower: 70 kW (95PS) / 6,000 rpm
o Torque: 123N m (12.5 kg m) / 4,600 rpm
• Honda Civic Hybrid (FD3)
LEA
o Horsepower: 84 kW (114PS) / 6,000 rpm
o Torque: 145N m (14.8 kg m) / 4,800 rpm
• Honda CR-Z (ZF1)
N-SERIES DIESEL :
N22A
DOHC 16 valve (2,204 cc inside diameter × stroke: 85.0 × 97.1) Compression ratio 16.7 Specification Reference: 103 kW (140PS) / 4,000 rpm 340Nm (34.7kgm) / 2,000 rpm (CN1 Accord)
• Accord (CN1)
• Accord Tourer (CN2)
• FR-V: (Edix in Japan) (BE5)
• CR-V (ED9/RE6)
• Civic (FK3 / FN3)
N22B
N22A to the rear of the exhaust, N22B has changed its front exhaust. The stroke also reduces emissions below the 2.2-liter.
DOHC 16 valve (2,199 cc inside diameter × stroke: 85.0 × 96.9) Compression ratio 16.3 Specification Reference: 110 kW (150PS) / 4,000 rpm 350Nm (35.7kgm) / 2,000 rpm
Corresponding Euro5
DOHC
N22A2 Specifications
• Bore & Stroke: 85.0mm x 97.1mm
• Cylinder Layout: inline 4
• Displacement: 2204 cc
• Valve Configuration: 16 valve DOHC
• Type: i-CTDi
• Compression ratio: 16.7:1
• Max boost: 13.5 PSI (0.93 BAR)
• Max power: 140 hp @ 4000 rpm
• Max torque: 251 ft•lbf @ 2000 rpm
• Redline: 4500rpm
P-SERIES :
P07A
• I-DSI SOHC 6 valves
• Displacement: 658cc
• Inside diameter × stroke: 71.0 × 55.4
• Horsepower: 38kW (52PS) / 7,100 rpm
• Torque: 60N m (6.1kg m) / 3,600 rpm (JC1 Life)
o Honda Life (JC1 / 2)
o Honda Zest (JE1 / 2)
P07A (turbo version)
• I-DSI turbocharged SOHC 6 valves
• Specification Reference: 47kW (64PS) / 6,000 rpm
• Torque: 93N m (9.5kg m) / 4,000 rpm (JC1 Life)
Vehicles were equipped with
P07A
• Honda Life (JB5 / 6)
• Honda Zest (JE1 / 2)
• Honda Life (JB7 / 8)
R-SERIES :
R16
R16A
• Found in:
o 2007- Honda Civic (Singapore Local Market FD4,Egypt,Turkey)
Displacement: 1,595 cc (97.3 cu in)
Compression: 10.5:1
Bore & stroke: 81.0 mm × 77.4 mm (3.19 in × 3.05 in)
Power: 125 PS (92 kW; 123 bhp) @ 6200 rpm Net horsepower
Torque: 15.6 kgf•m (151 N•m (111 ft•lbf)) @ 4200 rpm Net
R18
R18A
R18A1
• Found in:
o 2006+ Honda Civic (JDM FD1, American/Canadian-market FA1 and FG1)
Displacement: 1,799 cc (109.8 cu in)
Compression: 10.5:1
Bore & stroke: 81.0 mm × 87.3 mm (3.19 in × 3.44 in)
Power: 140 PS (103 kW; 138 bhp) @ 6300 rpm (Japanese Spec)
Torque: 17.7 kgf•m (174 N•m (128 ft•lbf)) @ 4300 rpm
R18A2
• Found in:
o 2007- Honda Civic (European-market FN1 & FK2)
Compression: 10.5:1
R20
R20A1
• Found in:
o 2007- Honda CR-V (RE1, RE2)
Compression: 10.5:1
Bore & stroke: 81.0 mm × 96.9 mm (3.19 in × 3.81 in)
Power: 150 PS (110 kW; 148 bhp) @ 6200 rpm
Torque: 19.4 kgf•m (190 N•m (140 ft•lbf)) @ 4200 rpm
R20A2
• Found in:
o 2007- Honda CR-V (RE5)
Compression: 10.5:1
R20A3
• Found in:
o 2008- Honda Accord (CP1)
Compression: 10.5:1
Power: 156 PS (115 kW; 154 bhp) @ 6300 rpm
Torque: 19.3 kgf•m (189 N•m (139 ft•lbf)) @ 4300 rpm
VTEC-ENGINES:
DOHC VTEC
The VTEC system is a simple method of endowing the engine with multiple camshaft profiles optimized for low and high RPM operations. Instead of one cam lobe actuating each valve, there are two: one optimized for low-RPM stability & fuel efficiency; the other designed to maximize high-RPM power output. Switching between the two cam lobes is controlled by the ECU which takes account of engine oil pressure, engine temperature, vehicle speed, engine speed and throttle position. Using these inputs, the
ECU is programmed to switch from the low lift to the high lift cam lobes when the conditions mean that engine output will be improved. At the switch point a solenoid is actuated which allows oil pressure from a spool valve to operate a locking pin which binds the high RPM cam follower to the low rpm ones. From this point on, the poppet valve opens and closes according to the high-lift profile, which opens the valve further and for a longer time. The switch-over point is variable, between a minimum and maximum point, and is determined by engine load. The switch back from high to low rpm cams is set to occur at a lower engine speed than the up-switch to avoid a situation in which the engine is asked to operate continuously at or around the switch-over point.
Introduced as a DOHC system in the 1989 Honda Integra and Civic CRX SiR models sold in <st1:country-region><st1:place>Japan</st1:place></st1:country-region> and <st1:place>Europe</st1:place>, which used a 160 bhp (120 kW) variant of the B16A engine. The <st1:country-region><st1:place>US</st1:place></st1:country-region> market saw the first VTEC system with the introduction of the 1991 Acura NSX, which used a DOHC VTEC V6 with 280 bhp (210 kW). DOHC VTEC engines soon appeared in other vehicles, such as the 1992 Acura Integra GS-R (B17A 1.7 liter engine). And later in the 1992 Honda Prelude VTEC (H22 2.2 liter engine with 195 hp) and Honda Del Sol VTEC (B16A 1.6 liter engine). The Integra Type R (1996-2000) available in the Japanese market produces 200 bhp using a B18C 1.8 engine. Honda has also continued to develop other varieties and today offers several varieties of VTEC, such as i-VTEC and i-VTEC Hybrid.
SOHC VTEC
As popularity and marketing value of the VTEC system grew, Honda applied the system to SOHC (Single Over Head Cam) engines, which share a common camshaft for both intake and exhaust valves. The trade-off was that Honda's SOHC engines only benefitted from the VTEC mechanism on the intake valves. This is because VTEC requires a third center rocker arm and cam lobe (for each intake and exhaust side), and in the SOHC engine, the spark plugs are situated between the two exhaust rocker arms, leaving no room for the VTEC rocker arm. Additionally, the center lobe on the camshaft can only be utilized by either the intake or the exhaust, limiting the VTEC feature to one side.
However, beginning with the J37A4 3.7L SOHC V6 engine introduced on all 2009 Acura TL SH-AWD models, SOHC VTEC was incorporated for use with intake and exhaust valves. The intake and exhaust rocker shafts contain primary and secondary intake and exhaust rocker arms, respectively. The primary rocker arm contains the VTEC switching piston, while the secondary rocker arm contains the return spring. The term "primary" does not refer to which rocker arm forces the valve down during low-RPM engine operation. Rather, it refers to the rocker arm which contains the VTEC switching piston and receives oil from the rocker shaft.
The primary exhaust rocker arm contacts a low-profile camshaft lobe during low-RPM engine operation. Once VTEC engagement occurs, the oil pressure flowing from the exhaust rocker shaft into the primary exhaust rocker arm forces the VTEC switching piston into the secondary exhaust rocker arm, thus locking both exhaust rocker arms together. The high-profile camshaft lobe which normally contacts the secondary exhaust
rocker arm alone during low-RPM engine operation is able to move both exhaust rocker arms together which are locked as a unit.
The secondary intake rocker arm contacts a low-profile camshaft lobe during low-RPM engine operation. Once VTEC engagement occurs, the oil pressure flowing from the intake rocker shaft into the primary intake rocker arm forces the VTEC switching piston into the secondary intake rocker arm, thus locking both intake rocker arms together. The high-profile camshaft lobe which normally contacts the primary intake rocker alone during low-RPM engine operation is able to move both intake rocker arms together which are locked as a unit.
The difficulty of incorporating VTEC for both the intake and exhaust valves in a SOHC engine has been removed on the J37A4 by a novel design of the intake rocker arm. Each exhaust valve on the J37A4 corresponds to one primary and one secondary exhaust rocker arm. Therefore, there are a total of twelve primary exhaust rocker arms and twelve secondary exhaust rocker arms.
However, each secondary intake rocker arm is shaped similar to a "Y" which allows it to contact two intake valves at once. One primary intake rocker arm corresponds to each secondary intake rocker arm. As a result of this design, there are only six primary intake rocker arms and six secondary intake rocker arms.
VTEC-E
See also: :ja:VTEC-E
It is a version of SOHC VTEC, which was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve.
3STAGE VTEC
It is a version using 3 different cam profiles to control valve timing and lift. At about 1000-3000 RPM's, only one intake valve and both exhaust valves are used for fuel economy; at 3000-5400 RPM's, two intake valves and two exhaust valves are used; at 5500-7000 RPM's, the VTEC cam profile is used to increase power.
i-VTEC
See also: :ja:i-VTEC
(intelligent-VTEC)<SUP>[3]</SUP> introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the <st1:country-region><st1:place>U.S.</st1:place></st1:country-region>). In the <st1:country-region><st1:place>United States</st1:place></st1:country-region>, Honda first debuted the technology on the 2003 Honda Civic Si EP3 with the economy version.
Valve lift and duration are still limited to distinct low- and high-RPM profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuration) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to somewhat advanced at full throttle and low rpm. The effect is further optimization of torque output, especially at low and midrange RPM.
K-series
The K-Series motors have two different types of i-VTEC systems implemented. The first is for the performance motors like in the RSX Type S or the TSX and the other is for economy motors found in the CR-V or Accord. The performance i-VTEC system is basically the same as the DOHC VTEC system of the B16A's; both intake and exhaust have 3 cam lobes per cylinder. However the valvetrain has the added benefit of roller rockers and continuously variable intake cam timing. Performance i-VTEC is a combination of conventional DOHC VTEC with VTC.
The economy i-VTEC is more like the SOHC VTEC-E in that the intake cam has only two lobes, one very small and one larger, as well as no VTEC on the exhaust cam. The two types of motor are easily distinguishable by the factory rated power output: the performance motors make around 200 hp (150 kW) or more in stock form and the economy motors do not make much more than 160 hp (120 kW) from the factory.
R-series
The new SOHC i-VTEC implementation is an entirely new implementation that was introduced on the 2006 Honda Civic's R-series four cylinder SOHC engines. This implementation uses the so-called "fuel economy cam" and "high output cam" on one of the two intake valves of each cylinder (another intake valve is fixed). The "fuel economy cams" are designed to retard the closure of one intake valve and are activated between 1000-3500RPM and under low load condition. When "fuel economy cams" are activated, the intake valve closes well after the piston has started moving upwards in the compression stroke. During this time, the drive-by-wire throttle valve is open wider than normal. Due to the delayed closing of intake valve, a part of the intake mixture that has entered the combustion chamber is forced out again into the intake manifold. That way, the engine "emulates" a lower displacement than its actual one (its operation is also similar to an Atkinson cycle engine, with uneven compression and combustion strokes), which reduces pumping losses thus reducing fuel consumption and increases its efficiency. VTEC-off on the R18A means it can be considered to be running "high output cams". When the right conditions are achieved for fuel economy, VTEC engages the 2nd set, the 'low' or 'economy' cams. Thus VTEC-on on the R18A means it is running low cams.
According to Honda, this measure alone can reduce pumping losses by 16%. Under heavier loads, the engine switches back into its "high output cams", and it operates like a regular 4 stroke Otto cycle engine. This implementation of i-VTEC was initially introduced in the R18A1 engine found under the hood of the 8th generation Civic, with a displacement of 1.8 L and an output of 140 PS (100 kW; 140 hp). Recently, another variant was released, the 2.0 L R20A2 with an output of 150 PS (110 kW; 150 hp), which powers the EUDM version of the all-new CRV. SOHC i-VTEC
With the continued introduction of vastly different i-VTEC systems, one may assume that the term is now a catch-all for creative valve control technologies from Honda.
i-VTEC VCM
In 2003, Honda introduced an i-VTEC V6 (an update of the J-series) that includes Honda's cylinder deactivation technology which closes the valves on one bank of (3) cylinders during light load and low speed (below 80 km/h (50 mph)) operation. The technology was originally introduced to the <st1:country-region><st1:place>US</st1:place></st1:country-region> on the Honda Odyssey minivan, and can now be found on the Honda Accord Hybrid, the 2006 Honda Pilot, and the 2008 Honda Accord.
i-VTEC VCM was also used in 1.3L 4-cylinder engines used in Honda Civic Hybrid.<SUP>[4]</SUP>
i-VTEC i
It is a version of i-VTEC with direct injection.
It was first used in 2003 Honda Stream.
AVTEC
The AVTEC (Advanced VTEC) engine was first announced in 2006.<SUP>[5]</SUP> It combines continuously variable valve lift and timing control with continuously variable phase control. Honda originally planned to produce vehicles with AVTEC engines within next 3 years.
Although it was speculated that it would first be used in 2008 Honda Accord, the vehicle only used the older engines.
A related <st1:country-region><st1:place>US</st1:place></st1:country-region> patent (6,968,819) was filed in 2005-01-05.<SUP>[6][7]</SUP>.
VTEC in motorcycles
Apart from the Japanese market-only Honda CBR400F Super Four HYPER VTEC,<SUP>[2]</SUP> introduced in 1983, the first worldwide implementation of VTEC technology in a motorcycle occurred with the introduction of Honda's VFR800 sportbike in 2002. Similar to the SOHC VTEC-E style, one intake valve remains closed until a threshold of 7000 rpm is reached, then the second valve is opened by an oil-pressure actuated pin. The dwell of the valves remains unchanged, as in the automobile VTEC-E, and little extra power is produced but with a smoothing-out of the torque curve. Critics maintain that VTEC adds little to the VFR experience while increasing the engine's complexity. Honda seem to agree: their VFR1200, a model announced in October 2009 to replace the VFR800, abandons the V-TEC concept in favour of a large capacity narrow-vee "unicam" (i.e. sohc) motor.
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
