Hello guys, your suggestions are required.
I am running Honda City IDSI 2004 Model since last 2 years, Since last two months i have felt that my engine is reducing a quarter oil after 2000 Kms, I got it checked found oil seal was leaked, fixed it on the spot plus cleaning of all engine. Now the problem is its again reducing oil.
I am using Caltex Havoline Motor Oil and used to change after every 3000KM as i have long and daily travel. I went to check it from three mechanics, i am writing their views
1- Its smaller amount of oil reduction, can be cause by some seeem (saaim around gear box) or due to Hot weather and AC is on, (like apka AC ziada chalta hai tu oil b burn hota hai etc).
2- Other mechanic said your engine is getting weak so its reducing oil.
3- Third mechanic also checked this there is very slight white smoke from the silencer but no black smoke. He then changed the oil with STP oil formula and said to run it for 3000 and see if its still reducing oil then engine will be replaced. The reason he quoted for oil reduction is that i have used some 2number Oil.
What should i do, engine oil reduction is start after 2000Km and i travel on a speed of 70-90km/h with AC on, no problem in running, no heating, and i can't feel smoke in massive amount.
I am totally confused on the situation. Please help.
