Is it worth to have inspection from 3s while periodic maintanance ? The inspection costs 5000/-
Just curious
What is included in Honda 3S inspection service??
what is problem and mileage which city
what you want to know
No problem till yet, I dont think Spark Plugs have to he changed as well. Current mileage I'm getting is 12.2km/l with AC.
It is 2012 Model, this is major service 100,000KM.
They told me last time it includes tightening of bolts, suspension check, ATF check, other checks such as Spark Plugs, other fluids.
If I do opt Inspection then I won't be charged the labor charges for Engine oil and Filter change.
is car auto transmissionplugs should be changed after every 100k kmsno need Honda dealership inspection can be checked by any good technician which has good reputation
I have kept city for 31000 kms..never paid on 3s for any such services. Just oil filters..and tyre swapping after every 10k kms with alignment check. Car is now with my friend at 55k kms and only thing just changed is brake pads and disc pads. Never used hobc..so cat also remained ok... Hobc walay sab bhai cat hi saaf kerwatay rehtay
If its not broken.. don't fix it live happily
city maintenance is dirt very cheap and very reliable just compromise on suspensionjust oil change nothing else even no tune up but must drive carefully never hard accelerator or braking
3s ka bus chakay to radiator main abe zam.zam.dalwa dein.. fazool expensive maintenance packages
Yes it is auto transmission.
I'm curious about the plugs, they cost 15,400/- from 3s which is why I first wat to get them checked.
If they're fine I'll get them changed in next service.
Thank you for the advice sir. I guess I won't get the inspection done however I'll just ask them to have a quick look on the plugs.
Haan I guess I'd have to get coolant as well. Mei bus jo periodic hoti ha wohi kerwa longa with additional coolant top up.
Spark Plugs ka i'll ask them to have a look on them and advice. I'm curious because 100K hogaya ha and I haven't changed Spark Plugs yet.
Wesay drive me toa mujhe koe disturbance feel nahi ho rahi and I'm getting a mileage of 12.2 with AC as well. I don't feel k spark plugs change kerna ki zaroorat hogi.
very nice mileage mashallahhope changed ATF on 80k kms as required after every 40k kmengine oil using 5w30 3.7l with oil filter
100k hai to plugs badal lo wasay ap
Hi Amir,
Yes ATF was first changed at 40K then at 80K and now due at 120K
3s was using 5w-30 till 90K however they used 10W-40 at 95K service. I feel 5w-30 was perfectly fine.
Would you recommend me to use 10w grade or stick to 5w ?
Thank you for the advice.
Mei change kerwa leta hoon phir.
Unki cost 15,400/- ha isliya I thought to get some suggestions.
15400 just for plugs?
Get from PartsCentral
if engine is perfect then 5w30 3.7l
