Yes, the brake upgrade is my list of things to do eventually. While the alto did not have the best possible brakes, with good quality pads, they do perform quite reasonably. In addition, I've used a different servo+master cylinder, which has improved the braking. With the previous servo+master cylinder setup, it was more prone to skidding, however, I was surprised to see the noticeable difference that the current setup has. I'm guessing that the front and back brake bias was not as good with the previous setup as it is now.
That said, I have not had any issues with the brakes prior to the swap and with little weight difference between now and then, it shouldnt affect the braking a lot. An important thing to consider here is that the main purpose of this car will continue to be a carefully, daily driven vehicle and not a vehicle to race in. The bigger engine would definitely mean that in addition to the horsepower, the low end torque is much better than the previous configuration, which, in turn would mean that the engine is a lot more relaxed while being daily driven, compared to the effort that the F10 had to put in. The less weight definitely helps as well.
As far as I remember, this city was the first car with a CVT transmission in the Pakistani market. Since then, I have had and still continue to have people in my circle who have varios and are getting excellent fuel economy, this was one of the most noteworthy features of this shape of the city when it was introduced. However, it is important to note that just like any other vehicle, they need to be maintained properly to get good fuel average. Secondly, as much as the fuel economy was a requirement from this swap, automatic transmission was another one that I would not compromise on.
Around 4 years back when I got this car, swapping that engine into it was the plan. But I couldnt get around to swapping the engine at that time. Fast-forward to today, that swap no longer made sense to me, when you could get similar or better fuel average with much better performance with the L13.
