Assalamulaikum all. I hope you are all doing well. I haven’t posted at Pakwheels for a long time so I’m here with another project.
The car in question is a 2002 HA12 Alto. It’s a PKDM variant which originally came with an F10A engine. The engine was a little over 300,000km driven but it was still running strong. I was getting around 14km/l within city (I know it’s unbelievable for this engine but a combination of keeping it well-maintained, different jets in the carburetor and light foot driving helped achieve this.)
The idea behind this swap was to improve the fuel average of the vehicle with the insane fuel prices these days and to convert the transmission to auto. If I could get better performance, that would also be a plus. Now I could go the safe route of a K6 auto swap to get better fuel average but that wouldn’t have cut it because of the lack of power. I could use a K6 turbo instead but that wouldn’t help me achieve the fuel average figure that I was after.
Therefore, with limited options to achieve what I wanted, I decided to swap in a Honda L-13A IDSi with a CVT transmission into it. Why an L-13A I hear you ask? a) It is known to have good fuel average, even in heavier cars such as the Honda City, Civic and the Honda Jazz/Fit, b) It would have a CVT Transmission, therefore helping achieve the auto transmission bit and c) with 85hp and about 120nm torque, it would offer good power to weight ratio in a car that weighs a little shy of 700kg.
I have an ongoing series of Videos for this project on my channel, you may visit the channel at,
www.youtube.com/@funcariauto/
Here are some specifications of the engine.
Engine Code: L13A
Engine Capacity: 1339cc (Offered in the 1.4 Honda Jazz GG/Fit GE, 1.4 Honda Civic FD)
No. of Cylinders: 4
IDSi – Intelligent Dual Sequential Ignition, which means there are Two Plugs per cylinder, sequentially fired for better efficiency.
Power: 85hp @5700RPM / 120nm Torque @2800RPM
Compression Ratio: 10.8:1
7 Speed CVT-Transmission (SWRA)
Most of the work on it is done in-house, which includes mechanical, fabrication, electrical and aesthetic. So let’s begin the process.
The car, just before going under the knife.
On jack stands and dismantling started.
The engine bay before the swap.
