Bro this has been already discussed here those numbers are always confusing in
70cc motorcycles and now as you see in pridor meter it is said these numbers
shows gears if that is the case than obviously these numbers are illogical
Let me give you an example look in past this is CD70 2010 model
now if we see these numbers here in this meter "1" is on 20km/h
now it seems illogical number "1" should be on 0km/h
but some people reads it as these numbers shows the max: speed of
gears so number "1" on 20km/h indicates the max: speed of 1st gear
what ever it seems illogical "1" should be on 0km/h
Now here is the pic of CD70 2012 model
AHl has re-positioned these now they have put the "1" on 0km/h but if we believe
on that these numbers shows the max: speed of gears than in this meter 3rd gear
has max: speed from 60 to 80km/h now 80km/h is the top speed for 70cc
but that it hardly achieves with some guys with low weight so this again seems illogical
placing of numbers samee in 2010 CD70 meter format its the same case with particular gear they seem wrong
This would have been correct placing of numbers for CD70 2012 as now they have put the "1"
number of 0km/h "1" @0km/h "2" @20-25km/h "3" @40-45km/h "4" @60-65km/h now
this would be pretty acceptable and for Pridor correct placing of these numbers should be like
"1" @0km/h "2" @20-25km/h "3" @45-50km/h "4" max @75-80km/h
Now this above placing of numbers would been fine and acceptable for Pridor meter
