During middle of process i found out Gear is not available @ home
but luckily there was gear oil available in Ketchup bottle
i mean the ketchup bottle which i use for chain lubrication
thorha gear oil filter kee ooper daala aur thorha haath par laga ke
jaise hair oil lagaate waise lagaya filter pe it was easy & quick that way
than again left the airfilter on sun light for about 15 minutes
Clean Airfilter after whole process
Cleaned the inside of airfilter compartment
installed the airfilter
used little bit of grease on botls
*Never tight these bolts too much
*During the process of cleaning airfilter when using kerosene or gear oil
i highly recommend you should wear rubber gloves as these materials
can be harmful for our skin
