Model NRX1800
Engine Type
1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke
74mm x 71mm
Compression Ratio
9.8:1
Valve Train
SOHC; two valves per cylinder
Carburetion
PGM-FI with automatic choke
Ignition
Computer-controlled digital with three-dimensional mapping
Transmission
Five-speed
Final Drive
Shaft
Suspension
Front: Trailing bottom-link; 3.9 inches of travel
Rear: Unit Pro-Link with single shock; 3.9 inches of travel
Brakes
Front: Dual full-floating 330mm discs with three-piston calipers
Rear: Single 336mm disc with two-piston caliper
Tires
Front: 150/60R-18 radial
Rear: 180/55R-17 radial
Wheelbase
68.9 inches
Seat Height
27.2 inches
Dry Weight
794 pounds
Fuel Capacity
6.1 gallons
Colors
Illusion Blue
Double Clear Coat Black
Candy Black Cherry
