I have a Honda and there are multiple lights on I did the ohms test and discover that it is 120 ohms so a resistor is blown but how can I check it and which module has the resistor
Ohm test? where you tested ?
Can high and low pin 4 and 14 on the obd port
The hybrid system, abs , steering not working but the engine starting
You should get your car scanned with launch scanner. Because Chinese scanner will not work.
I did and still no communication and there is no volts on pin 4 and 14 on the obd port
4 is ground pin. They are not analog signals where you can use multimeter. Did someone messed with wiring?
Duplicate thread.
