I've had my 2022 model 125f for about 1 yr now.
It is an ok bike. We only use it to ride around the colony for occasional errands. Nothing more. In one year or riding, it has only done 1850 Kms.
However, there have been so many quality issues.
1) Rear suspension arm bushings squeak. Took 2 honda locations 4 times to repair this issue. They tried greasing it and then a new bushing. Ended up having to replace the entire arm. Warranty replaced.
2) spark plug failed. Warranty replaced
3) bolts rusty. The bolts on the suspension forks, handle Bar and more have rusted. My bike stays parked a lot and usually under a cover. Yet somehow, rust has creeped in. Even the rear chain sprocket is rusty already. Honda's solution? Use black paint over the rust
4) headlight failed. Had honda inspect. They cracked the headlight cover too. Ended up never going there again as they said 'it was already like that'
5) front tire is weather cracked after only 1 yr.
Apart from that, it's an 'ok' bike. Would I buy one again? NEVER.
I wanted to buy the gr150, but the dealership said it's a 4 month wait which is why I went for the honda instead.
