bahi drift can never be possible on front wheel drive car , and 4 wheel drive car
there is a lot and lot of science to eplian what is attcually drifts means
only rear wheel car drift
but they have be be very powerfull
like approximately 180+ break horse power and massive toqruee to let burnout continue in sliding position
nest thing is that , we cant drift on stock car (RWD)
cause they are mostly have sepecial freatures , like
traction control system , abs , anti lock bracking system
etc etc
they all have be disable , if they are eneble their function will tend car to gain their equilibrium , they wont allow car to loose grip , they wont allow car to let slide , and they will reduce burn out , which causes wastage of power on that time etc etc
thing need to be change expecially
suspension system
tyres ( lowest grip - higly desing for drift ,have hard rubber )
steering component ( changing ratio of steering )
hight performance stuuf for engine like , polished manifold , exhaust kit , air intake , high flux spark plug , etc etc
it also depend on power:weight ratio
lack of power wont be able to continue drift it will not cause continuus sliding through burout
excess of power will also loose control of the car
it will spun out
these information are minimum for drifting
