Guys I want to add an option of USB in my Alto, initially i was planning to replace the pre but the original one is an In Dash and it will be a khuwari to change it.I want to add a USB option in it but want the sound to perfect as it is with CD, because i listen to music at high volume and sound quality matters a lot.Secondly i want to add a pair of speakers in it. Want quality bass that is enough to bang the cabin.PS: Don't suggest an mp3 modulator, its crap.Here is my Cars pre.
umm mp3 modulator transmits fm radio signals that u tune from ur player, that ruins audio quality, if u want to keep this player u'll have to DIY an mp3, usb player(don't know exact name, the one that comes in usb speakers) to aux of this player.
Yup once installed an Fm Modulator and threw it out the next day, it was awful, Can some audio shop install a usb input in this,?PS; i am a commerce student and not good at such DIYS
yup, try visiting those who make and install cheap usb players.(if u can't find any go to visit a shop thats into after market stuff for bolan )
lol ok, gonna go to market and see what i can find
i tried that 2 times. visited plaza and tariq road. it can be installed and costs only 500 rs but the sound will be the same as that of a fm modulator. but if you find a good solution, then let me know.
was searching and found this thread, looks good but impossible to do it myself, needs someone who understands electronics, i wonder how the sound quality will behere is the link of the threadhttps://www.pakwheels.com/forums/d-i-y-projects/184661-d-i-y-usb-aux-card-reader-rs-260-a-3
I won't recommend playing with such electronics of car instead of such things try to live without music
Install USB,Card Reader Pre and Install Rockmars Amp With Pioneer woofer you will have awesome Bass
Sent from my iPad using PW Forums
I can simply not drive without Music
The problem is the cars own pre, It is an indash so cant change it, was thinking of adding speakers in the rear. any idea of this And is it possible to use USB or AUX directly with Amp
You cannot use USB with this in anyway except via FM Modulator.
Yes AUX can work directly with amp..via Y-RCA to 3.5mm connector
Ok so i Can use AUX directly with Amp, will the sound quality be perfect? ill be running a woofer and a pair of speakers with it,
Yes you can use an AUX directly with the amp an the quality will be good (i tried it myself) The only thing you'll have to be careful about is the volume of the mobile which is usually at full
Couldn't understand the mobile volume part,Its time to look for an Amp
When you are using AUX directly with the amp then the AUX is will be giving it maximum output through amp . When you plug aux in mobile and play songs , make sure the volume of mobile is low , else you'll get a new surprise everytime
Oh so u meant that when i use AUX with amp directly i should keep the mobile volume low?Any good 4 channel used amp in sight?
Exactly , thats the point .
None atm , i'll search for you
Thanks bro, do let me know if u come across one as im not that good with Audio Stuff
Which Woofer and Amp you are going? I've cancelled the plan of selling eK and i'll also install Amp with Woofer in my car
I'm thinking of New rockmars amp with pioneer Woofer, it will have enough bass!
