AoA
I recently purchased Old model Honda Cg 125 (2011) and maintain it approx in actual condition, most of the work I am doing by my self and in case if required some mechanic then i will perform the whole repair with him to avoid any issue later.... Alhamdolilah this practice going fine...
As I purchased a used bike so now its weight is creating issue while running there is a constant sound from the right side which is the clutch side. I am confused whether its the small clutch gear sound or the weight sound... I am confused as while kick start a bit jam feeling and secondly the bike is not sustaining on slow RPMs.... today i checked its tapet assembly is also need to replace. (its new and genuine price is 900Rs).
I am requesting to all seniors and gurus to advise on this confusion as i am not in a position to open the engine due to further expenses. If there is any other way to check this.....
Minimum Low RPMs are 1.5
The maximum speed is 115km/h i have checked .... wont go for 120
less vibration smooth ride
no smoke, no fuel overconsumption, no engine leakage.
Always full oil drain while changing.
