In case of old vehicle, rust or debris can accumulate at the end of the master cylinder. Pressing the brake fully to the floor will move the master cylinder piston seals all the way to end can cause damage to them. This can cause loss of braking pressure.
I don't think this will be an issue if you routinely change the brake fluid every year or two
