@panther,
you are welcome.
As the other honorable members have given you the insight about checking of ABS, I will just try to put my 2 cents in:
1) Turn on the ignition switch to 2nd position, meaning when all the lights come on (without starting the vehicle).
2) You will note apart from other indicators that the ABS indicator will turn on.
3)Now start the vehicle, all the other lights go out, The ABS light may go off the last, meaning 0.5-1 second after the other(this is normal and perfectly OK)
4)However after this interval, it should turn off completely and should not come on again! If it comes on again or is taking like 1 minute to turn off then there may be problem with the sensors or any other thing in ABS.
5) Now drive the car and in increase the speed so that you feel that when you apply sudden brakes the regular cars without ABS will screech. Now apply sudden hard brake and DoNot release the brake paddle. You will feel the brake paddle pulsating or shuddering (this is NORMAL) and you DONOT take your foot off the paddle in a real emergency situation.
6)You will not hear the screeches made by the ABS equipped car because it doesn't allow the wheels to lockup.
7) On a wet road you will not even have to increase the speed of the vehicle too much for the ABS to kick in!
8) Kindly when you perform the ABS testing do it on an EMPTY stretch of road to avoid any accidents. Also donot push the vehicle very hard without any ACTUAL emergency for testing the brakes or you will over heat the brakes of the potential car you are buying. Just do a normal test!
NOTE: There is misconception in our drivers that ABS equipped car will do wonders as far as the stopping distance is concerned. Mark the words :"The braking distance of an ABS equipped car and that of a NON ABS car is EQUAL, SO DONOT HAVE THE MISCONCEPTION THAT THE ABS EQUIPPED CAR WILL STOP IN A SHORTER DISTANCE. The only ADVANTAGE which you have with an ABS equipped car is that you can Maneuver the vehicle (meaning that you can turn the steering wheel slightly to avoid the obstacle in front of you and come back to your original lane without losing control of the vehicle)". All this will be done when simultaneously you have pressed"hard the brake paddle without letting it go when you feel the shudder. If you release the brake paddle during the shuddering than you will do worse than a regular car as far as braking is concerned!
Hope this helps!
