@iceman_kimi
2: While the engine is running open the engine cap (the round one). Invert it and check if its inside is oily. You could also place your hand on the hole left by this cap (if the engine cover is not too hot) and rev the car a bit. If you get oil on your palms that means the engine is weak.
that's a very very dumb way of checking an engine.
3: Water drops coming out of the silencer also represent a good engine. (I'm not too sure about this one though).
NO. Water drops from exhause does NOT mean anything. Its only condensation. Does not mean engine is good or bad.
A strong engine only darkens the engine oil doesn't decrease it.
Says who? Even brand new engines burn oil as they get Hot. Small engines burn less. 6 or 8 cylinder burn more and more.
i.e. within the cylinders where combustion is taking place. This happens because rings/ pistons are de-shaped/ damaged in such a way that they can not keep the oil at the bottom from entering the compression/ combustion area above the piston.
if that's true.. wouldn't you see smoke comming out of the engine?
@Naveed
major noises include broken rings and excessive piston wear but you have to have an ear to identify all of these noises.....
I am sure if you have a engine with broken rings... you can hear LOUD noises from far away....
and if the rings were actually broken... engine wouldn't run good for a very long time.
- get a compression. don't remember the exact values but i think above 10 is ok
It's actually between 90-120 PSI
@lodhi12
Loss of compression on any 1 Cylinder doesnt mean anything. Usually occurs in CNG cars. Just give the combustion chamber some oil to drink. It will be fine.
It doesn't ? Why not.. would you like to explain?
