do an inspection before starting the car.
remove the oil cap and look at the enigne for any gunk or gaskit failure.
start te car and remove te radiator cap when its not hot and look for bubbles, gaskit failure.
slide under the car for any visible leaks.
look for smoke from exhaust.
check for car noise on ideling and while you are driving.
if cng check the car on cng wheter its giving problem, also check for heatup issues.
if you wanna be meticulous take the car to an aquainted mechanic.
if really really wanna be more precise then do a compression test (you have to buy the kit from abroad:'()
