Meri gardi k battery drain buht jaldi hoti koi bata sakta hy k es ki kiya waja hy aur es ko kaisy check karwa sakty hain aur kis bandy par karna chaheye
Which model is your carHow much is your car driven Do you have shorter trips or longer trips
For hybrid battery health you can check the individual voltages of each bank/cell from a good scanner and compare with original.
Model= 2014Driven= 80000 Shorter trips is less. Used it for long trip mostly
brother aap ko koi athentic workshop ka pata hy. Jahan es ko check karwa sakoon
Long trips pe obviously battery charge hi less hogi and then khatam bhi jaldi lekin you can still get it checked.
It depends on which city are you from.
