FGTech Galletto 2 Master V51 BDM-TriCore-OBD is obd2motor famous chip tuning tool for all cars, trucks, motorcycles, Marine, BDM MPCxx, BDM Boot Mode Tricore, checksum. This item cannot only work as FGTech Galletto 2 Master, but can also work for BDM-TriCore-OBD.can support Italiano, English, Deutsch, Francais, Espanol, Portugues, Czech, Turkish multi-language.
present-day different cars have an on-board computer called an engine control unit (ECU) , and which controls activities such as timing, emissions and fuel supply. The ECU is programmed at the factory for ordinary driving conditions encountered by the average driver.
Galletto 2 BDM TriCore OBD Often a driver will want to re-program the ECU to provide better performance or gas mileage. The FGTech master has an on-board diagnostic chip (OBD) which allows the driver to access the ECU. The OBD is a cable port usually found under the dash board. OBD2 equipped ECU's can be updated with a hand-held scanner.
Use new Galletto 2 connection to download the ECU settings. Engine accessories such as headers or cylinder heads will usually come with a disk loaded with new settings.
Plug the USB cable into the FGTech Galletto V51. Insert the disk and scan the new settings.
Turn the ignition to the "ON" position. Find the OBD2 port on the vehicle. Plug fgtech master V51 into the port with the cable included in the scanner kit.
Turn the FGTech V51 on and let it access the ECU.
Follow the FGTech Galletto 2 Master BDM TriCore OBD instructions to upload the new settings into the ECU.
More information,welcome to our web: www.obd2motor.com.
