the rear bench needs to be pushed inward [ towards trunk ] and pull up, once released pull out bench. Then you will see 2 hooks extended from seat-back bolted to rear frame remove the bolts and carefully push the seat back up to remove from rear frame hook clips. to re-install reverse the process
figure is for reference only
