Follow these steps.
1. Open the right side front door.
2. Sit on the driver seat.
3. Reach out towards the B pillar with your right hand, you will find something dangling there dont be afraid, it is a seatbelt, pull it around your torso and insert it in the red hole between the seats which says push. You will hear a clicking sound which means you are buckled up.
4. Now recite prayer for your journey "SUBHANALLAZI SAKHARA LANA HAZA WAMA KUNA, LAHOO MUQRENEEN, WA INA ILA RUBBINA LA MUNQALIBUN."
5. Now put your hand on the gear lever and make sure that it is in neutral position before your turn the key.
6. Turn the ignition key until the car starts, you will hear cranking chey chey chey chey then the engine sound dhur dhur dhur dhur.
7. Behind your steering are two sticks they are called stalks, the one on the right is the turn signal(jndicator)/light stalk, the left one is for wipers.
8. Hold the right stalk (turn signal wali) from the end and twist it clock wise, your dash will light up on first click, on second click lights will turn on, lumos.
9. For indicator left push this stick up, for indicator right push it down, for no indicator put in middle, for indicator left and right both find red button. Indicator auto shut off when turn.
10. Drive safe and obey the laws of the road.
Bonus tip: these instructions might workout on other cars. But remember chevrolet joy and some other cars have indicator on left side.
