What is the goal here? Preventing premature detonation, or something else? Please note that retarding the timing delays the spark relative to the piston stroke cycle, so the burn is initiated later, not earlier, and, as you note, it does not change the compression itself.
Stacking head gaskets on a four stroke will need adjustment of the timing chain, and adjusting the valve timing accordingly since all the factory marks will be off.
