Greetings!
The question is with the use of regular CNG Regulators/Kits eg Landi Renzo GasPetro etc the unfiltered CNG gets into the the intake manifold and thus will also go to the valve seals etc.
This is obviously Not good for the Gasoline engine. It will not affect the engine immediately, however when the engine is driven 40-50,000km eventually it will start to deteriorate the Cylinder Head of the engine.
Can any of the worthy members give ideas about how to filter the CNG before it gets into the engine?
As an analogy we can take the example of regular gasoline/petrol filters which prevents contaminants getting into the engine?
Is there any way to install a CNG filter starting from the fuel tank all the way to the CNG regulator?
CNG filters are installed in the SIS kits eg Liana, however the question here is about the regular CNG kits?
Thanks
