The problem is that it require's a lot of trouble shooting. and eventually the culprit comes out as damaged rubber or possibly a loose screw. Something that might take hours to diagnose but seconds to repair. So it is best that you at least try to find out where the sound is coming from. If you can localise it, then your and mechanic's job would be much easier.
